7030??
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: 7030??
    Posted: 26 Mar 2020 at 1:26pm
Anyone see anything odd about this photo?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 1:35pm
Hood decals too high and crooked. Grille emblem too low. Engine oil cooler the newer aluminum housing instead of cast iron. Acousta cab #2 with flat front. Radial tire on left front.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 3:26pm
Orange axles (should be black)
Two lights in the center top of the cab (wth?)
It looks lonely and in need of a good home...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 3:40pm
Yes DrAllis & Brian F(IL). It was advertised as SN: 70301763 ?
Edited by AC7060IL - 26 Mar 2020 at 3:42pm
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 5:49pm
So is your "sluicing" a good or bad thing?? Do the descrepincies  in the add make it a game-changer?? Just asking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:34pm
It either never had a cab to begin with and sometime after the Fall of 1977 they bought a new current production cab, or the tractor had a factory cab and it got rolled over sometime after Fall of 1977 and the cab was replaced with the current production cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:43pm
Thank you, thought maybe a previous owner might have done some "shade tree" upgrades for the better. Lipstick on a pig is probably the better scenario Embarrassed .
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:48pm
Actually looks like the left side hood decal is on the right, besides being high.
Edited by NE GA Allis - 26 Mar 2020 at 8:49pm
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:50pm
DrAllis, which models received the cast housing oil coolers? Which models received the aluminum oil cooler housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 9:00pm
Good catch on the backward decal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 9:01pm
Early 7030/7050's had cast iron oil coolers that were square like a box. Aluminum came later on and was cheaper to make I suspect.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 6:30am
No batteries
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 6:50am
Sluicing???
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 5:32pm
"detective/ investigation", you did take grammar/english classes in middle school??Confused
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 6:18pm
Well middle school was a long time ago. So now I'm wondering how I should take what you said here. And then I'll ask was it a long time ago that you took grammar/english? Wink
Edited by Lonn - 27 Mar 2020 at 6:33pm
Wink
I am a Russian Bot
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 10:19pm
I am not an English major but I thought the correct term should be sleuthing?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2020 at 8:42am
Sluicing has a meaning therefore the statement FREEDGUY typed could be considered almost coded. Sluicing means making a statement without stating all the words but the statement would still be understood. A simple example would be .... Fred can repair a carburetor, not Dennis..... It's assumed that Dennis cannot repair a carburetor without the statement being completed. That is sluicing.
Also sluice or sluiced means wash or washed. Had to look that one up.
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2020 at 11:07am
I’d also think sleuthing is a much better fit, but??? Dang freedguy, don’t you hate it when you try and play grammar smartass and autocorrect makes you look dumb?😂
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2020 at 6:25pm
Nope, apparently had Gold Rush on my mind. At least my spelling was correct. More than I can say for some Wink
This page was generated in 0.238 seconds.
