Case 480 backhoe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Case 480 backhoe
    Posted: 25 Mar 2020 at 8:45pm
I have a project hoe I am working on. Doesn't want to shift gears. I think the valve than dumps pressure to tranny and torque convert is stuck. Any Case experts on here?  Any help appreciated.Thanks Tracy
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 8:54pm
 Hey Tracy,,,I ain't a case expert,,,,but I did stay at a motel 6 in Australia,,,,,,,gulp,,,,I'm outa heere,,,,,WinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 9:32pm
Joe, stay safe! Traveling may be dangerous! Tracy
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 12:09pm
Both of mine are 1968 580ck's but same workings. 1 of mine is direct drive and 1 is converter drive. I have never used the converter drive one and only use it for parts hoe ---dont like anything thats not direct drive.
I have a bunch of books on 580's and one of them might cover the converter drive unit. I would say that some valve is stuck/sluggish making the trans not release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 7:11pm
ac fleet, mine is a power shuttle shift. Both brakes are on left side. Shuttle disconnect pedal on the right. There is also a switch on dash for drive or road. I think it allows to stop machine with disconnect pedal. I have all the manuals , but must have been written a college professor. Thanks Tracy
Edited by Tracy Martin TN - 26 Mar 2020 at 7:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 8:24pm
Hmmmm,---not sure the 580 has any switches,---does have both brake peddles on the right, but so does the direct drive one. Gotta remember to look at it the next time I get to the farm.
Drove a Ford 555 that had that setup, ---stomp the clutch peddle, grab trans gear you wanted, dump clutch, mash throttle peddle and go.--- to stop, let off throttle, grab reverse lever and stick it in the other direction and mash throttle again. At idle it just sat there. ---never ground any gears.
Took me a while to learn how run it not having an actual clutch !
This page was generated in 0.398 seconds.
