wd45 hyd pump
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Topic: wd45 hyd pump
    Posted: 21 Aug 2010 at 1:49pm
when i have my plow hooked to the tractor and it's in the up position and tractor is idling and clutch is out..i hear a knocking or tapping in the trans...i was told it's the pump bypassing...if i clutch the tractor or idle up a little it goes away...is this normal or a problem?  hydraulics seem to work good and normal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 1:49pm
oh and i did drain the hydraulics when i got it and fill back up with 20w non detergent
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 1:52pm
That's pretty normal. I don't know if it is the pistons in the pump knocking or if it is the unloader spool hammering, but is nothing to worry about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 2:00pm
ok just curious...never had a tractor do that before...sure can make a feller nervous to start hearing that!
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 2:32pm
Normal.I grew up with it so I never knew the difference.
Max(ia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max(ia) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 4:05pm
My CA does that, but if I put the lever in hold position after the blade is raised, it stops
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 4:24pm
ok thanks guys...eased my mind
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 5:17pm
Jeff...
... does this mean you found the source of the original "noise"?
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 8:27pm
That is some primitive hydraulics by todays standards.   Its likely just not sealing somewhere and running ever so slightly to keep pressure.  Mine does the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 8:55pm
nope John, this is all together different, maybe the original noise is like you said about your cat, all my bad deeds coming back and making me paranoid?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 9:12pm
Well, I can't speak for you - but my cat deserves it!
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 9:35pm
I think Max nailed it; if the lever is not moved back to the hold position after the rams reach their maximum lift, the hydraulic system is recycling oil thru the unloader valve and will sometimes make that kind of a sound. I have one WD-45 that "knocks" like that much more than either my other WD-45 or the WD, but they all do it to some extent.
