2012 F250 2WD Front Rotor Removal
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: 2012 F250 2WD Front Rotor Removal
    Posted: 20 Mar 2020 at 4:04pm
I got two that are stuck on.  looked at a bazillion you tubes.  Confused
I think this model is spose to slide right off the hub with a little persuasion.  I been up to a 4 lb hammer and also tried the pushing with a bolt and nut through the caliper mount.
I can't get these things to budge.  Oh and used ample krioil.
I hope somebody can bail me out on this one.
thanks.
Edited by Dave H - 20 Mar 2020 at 6:02pm
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2020 at 6:22pm
Keep beating from the backside out. When you put the new ones put some anti seize around the center of the rotor where it meets the hub.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2020 at 6:22pm
Most of it is rust on the inside of the rotor that expands and won't allow it to slide over the hub. Wail the chit out of it on the horizontal 'hat' part of the rotor to knock the rust off. It will help dislodge it from the hub too. If you have a light you can see behind it where the caliper mounts. If you think you have enough spray on it give it another shot.
Select your words carefully. It takes the right succession of profanity to make the magic work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2020 at 7:10pm
are you sure the disc is not part of the hub ?  "SOME" 2 wheel drives were made that way
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2020 at 9:27pm
Dang Steve, I did not find that you tube.  It looks exactly like my 2WD Ford.
I am going to yank that puppy apart tomorrow and go from there. Thanks, If you don't hear back shortly, no news is good news, but I will get back.
AAAArrrgggg, I can't believe it is gonna be 27 degrees in the am.  Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2020 at 9:44pm
tannerite or....trade it in for a good truck!
sho-man1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote sho-man1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:13am
My son was making a run to Little Rock to pick up a motorcycle using my F250SD.
He made is about an hour out when he heard clicking/rattling noise from front drivers side hub bearing. Told him to limp it back to Greenville, TX and I would bring more tools and  we can change bearings. I get to the O'Reilly's parking lot, he has the left front hub off but can't get the bearing inner race off the spindle., bearing was shot.
O'riely's and autozone didn't have a puller. The other O'riely's in town has a puller, i start to head over there but see a Greenville Fire truck and command truck setting across the street having a casual meeting. I swing by and ask them if any mechanics shops might be open at 7am on a saturday and explain what is going on. They all jumped up wanted to take a look.  Them fellows rolled up, popped out the jaws of life and an air chisel. They had the race off in a few seconds.
The crew from Station #4 went well above community service to help us out.
 So now we have a Northern Tools air chisel, would love to pickup a hydraulic or electric jaws of life. The fireman pinched the race then started working that thing off, would not budge. Air chisel with about three hits and it was gone...
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:21am
Some have a single or 2 screw on them to hold it in place while you put the caliper together. Small screws, but could hold you up.
I had one come off in pieces last year.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 12:19pm
A lot of them were 1 piece
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 3:26pm
First time I changed brakes on my 2013 F150 I had to thoroughly beat the wheel off because it was seized to the middle of the hub. The pilot hole surface on both the wheel and disc tend to seize from electrolysis, takes quite a bit of persuasion sometimes.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 3:55pm
Did you stop by the station house with a couple dozen donuts?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 4:58pm
John, they're all low carb keto eaters now days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2020 at 5:13am
Thanks for the interest folks and especially to steve(ill) for posting the vid.  My ole Ferd "get it" is back on its feet and outta of the barn.  Wink
That was also a reassuring post about the fire men (oops i meant persons) folks.
