AC 7040
combine pilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combine pilot Quote  Post ReplyReply Direct Link To This Post Topic: AC 7040
    Posted: 21 Aug 2010 at 7:27am
I have a AC 7040.I am having problems with the Power stering, it always pulls hard to one side. I have tryed bleediing the system and  replacing filters. Has anyone had this problem befpore? if so what do I need to fix it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 8:00am
If the steering "effort" is higher when turning to the right, I'd guess the flow divider/priority spool is stuck in the power steering pump OR the steering pump itself has some internal issues. I assume all other hydraulic functions work correctly?? and I also assume the front spindles have been thoroughly greased??
Post Options Post Options   Thanks (0) Thanks(0)   Quote combine pilot Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 11:51pm
Yes, the front spindles have been greased thoroughly. All other hydraulics work perfect. I will give the diverter/priority spool a look. What it does is turns to the right (if you let go of the steering)and hard (nearly impossible)to get it back straight. Was a real challenge to drive it 4 miles down the rode to get it home from the feild. Thanks for the advise.
