200 hydraulics/d17 serries 4 hydraulics
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: 200 hydraulics/d17 serries 4 hydraulics
    Posted: 16 Mar 2020 at 5:40pm
I have a 3 point log splitter with a hydraulic control valve on it. I always ran it with the D17. I would hook the hoses to the right side of the tractor, wire the right side hydraulic lever on the tractor back, and use the valve on the lot splitter to split wood. As I sold the D17 back to the original owners son, can I operate the log splitter the same way with the 200?. Thanks guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 6:02pm
I don't see why you couldn't.  It should work the same on any 2 way hydraulic hook up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 7:36pm
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 9:03pm
Best to screw self canceling screw all the way in to keep lever back.        MACK
