210 ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: 210 ??
    Posted: 12 Mar 2020 at 6:01pm
Was/is a 210 closer to a 220 chasis/tranny tractor or a 200? seems like there weren't many 210's produced? I grew up around a neighbor that ran 2 210's on his farm and I had the pleasure of running 1 of them during silage harvest, but there were never any 220's locally.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 6:07pm
It is a 220 under the sheet metal grill. The 200 has very little in common with a 210 or 220.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 6:18pm
Seems like a 200 is closer to a XT 190 diesel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 7:28pm
A 200 is an upgraded 190 XT with a differet grille, heavier 3 pt capacity, different color configerations - and there were cost reduction 200,s built to save money on them
Edited by DougG - 12 Mar 2020 at 7:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 9:07pm
210 has different nose and bolster....from there on back it's the same tractor. Pump might be spec'd a little different but looks same outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 9:17pm
210 is a 220 with some cast iron removed and replaced with tin.      MACK
