B112 questions
Ewhitford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ewhitford Quote  Post ReplyReply Direct Link To This Post Topic: B112 questions
    Posted: 09 Mar 2020 at 12:06pm
I have a b112 with a 16hpBriggs in it with a 1inch shaft for the crank.  What size in diameter should be used to power front attachments ?   2nd question,  I have no power to pull my garden trailer espesially going up hill.  I tried several belts, Watched the drive system and nothing seems to be slipping so what am I missing.  I have this issue whenever going up a hill or towing our sprayer, wagon or spreader.
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 8:29pm
Is it a variable speed
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2020 at 2:53pm
Check the pulley on the rear, mine throughs the out every so often, can't keep set screw tight.
Edited by tadams(OH) - 10 Mar 2020 at 2:54pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 9:31am
you cant beat that modal 32 briggs for power,   shaft is 1 inch for the snow blower  if the 16 has low power make sure somone has not put a flywheel on with the wrong ploarity i have seen done and it still runs but very poorly
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2020 at 9:49pm
Have you gone through the adjustments for the variable speed system in the service manual? These need to be adjusted periodically as the belt and linkages wear.
Animal Cracker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Animal Cracker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2020 at 4:21pm
You know its suppose to be a 12 hp right.
Orangeisgreat190 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeisgreat190 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 10:31am
I have a B112 with variable speed.  Try taking you heel and pulling back toward you on clutch pedal.  See if this helps.  If it does, I would say ACmowerguy is right, check all rearend adjustments in manual.  Also, I replaced the belt on mine and it helped tremendously.  The pulleys move in and out to change diameter for speed change.  This really wears on the side of the belt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeisgreat190 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 10:32am
Forgot to mention, check clutch return spring as well.  It could be weak.
