Welding on new sprockets
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Welding on new sprockets
    Posted: 07 Mar 2020 at 7:26am
Does anyone have the procedure for welding on new sprocket rings on an Hd11? Is it possible without pulling the sprocket off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 11:15am
Yes , on my HD5G  I had the sprocket ring and cut a section out to slip over the truck rail and outboard bearing . then welded that section back into ring and welded the spokes to the sprocket ring .
 The part is to heat the sprocket ring to expand it so when it cools it doesn't break or crack the welds to spokes of the hub .
 For my D6 I welded D5 Sprockets to D 6 Hub spokes again preheating the ring to expand so as it cooled and shrunk it got smaller and tighter to welds on spokes . That I did off the machine and as I was welding on one spoke you would hear a ping and a crack would show up on opposite side - heat full ring , grind out crack and weld again and reheat and weld again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 11:19am
one big part of the job is measuring everything close and knowing how much to cut off , make sure everything has a dimention to a known point as you can get sprocket in line with rest of machine when done - take a measurement so when you weld that section back in that you cut out of ring it is same across the distance between tooth as area not cut
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 9:16pm
I was hoping to be able to weld them on the machine to keep from pulling the sprockets off. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 11:40am
Yep - that is done by slicing about 5 teeth out of the ring - cutting the ring at low point of the tooth circle - a section taken out to be able to slip ring over the outboard bearing and truck frame support .
 When I did my D6 - I put a D5 segmented sprocket (bolt on teeth) onto D6 spokes .
On my HD5 - rather than remove the loader from truck frame and move the frame itself I cut the section from new sprocket ring and welded it back together then to HD5 spokes from hub .
 I seen a machine where a bolt on sprocket had a sprocket ring welded to the solid ring after old teeth were cut off - unsure of the reason if the center bolt pattern was damaged or if different track was used so different sprocket pitch was needed
Lazyts View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 7:13pm
I think if I was doing it on the machine I would cut the ring in half, and only cut one half of the old one off at a time- that way I could line it up at the same centerline as the old ring.  The first one I did, I took the frames off and welded the sprockets on the machine, and they ended up with a slight "wobble".  The next time I did one, I had the sprockets off, and I welded them on the bench- they ended up straight.  There are two different sprocket rings for HD11- one is about 1/2" thicker (newer style) than the other, but they can be interchanged in a pinch.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 10:46pm
How many amps did you have the welder turned up to for such a nice weld?
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 8:49pm
I used my "tombstone" welder- 7018AC 1/8" rod at 120 amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 9:07pm
Great looking job! That is craftsmanship! Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 9:37pm
7060... you should be able to weld the sprockets while installed on the machine.. Just keep rotating so you have the weld horizontal at the top.. easier to weld than vertical or angle...... and weld a rod to the hub to attach the ground cable... You dont want any stray current running thru the shaft / bearings to a remote ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 12:01pm
that is something many individuals do not think of when welding - WHERE IS THE GROUND - any current flowing through a bearing as a flirt with DISASTER .
 Same as any electric - was watching a guy weld on a truck bed - problem was the light switch was on - grounded through the lights and every bulb on the truck flashed ONCE and they were black inside bulb - dash lights included
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 1:42pm
Something else to help prevent the dreaded "ping" is to preheat both pieces you are welding, and then immediately weld and move to the opposite like tightening lug nuts.
Leon
