1950 WD Sitting |
Post Reply |
BKarpel
Bronze Level Joined: 27 Apr 2012 Location: Collinsville IL Points: 108 |
Posted: 06 Mar 2020 at 4:26pm |
We have a 1950 WD that has been sitting in a barn. My Grandpa passed away in 2009 and I only remember it running a handful of times in the last 20 years. It has a alternator and a 80's orange paint job. I turn the engine over with the hand crank a few times each year to keep it free. I think when he parked it the gas was turned off and ran till it died. Should I pull the carburetor off and clean it or just try my luck? Add battery,fresh gas and check points.
Edited by BKarpel - 06 Mar 2020 at 4:27pm |
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
It can't hurt to try it like it is.
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4453 |
I agree. You can't hurt anything by trying. I would probably squirt some gas through the carb before I tried it. I use a 20 cc syringe that works great for that. I would probably push it outside before trying it. I've had a few brushes with fire from trying to start a gas tractor.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3234 |
My late FIL had a Super M under those same conditions. We just added gas and it ran real well. Even on crappy gas drained from other cars that had been sitting just as long.
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 613 |
I would throw a battery in it, fresh gas and give it a spin. Thats what I did with my 47 B when we got it back from the guy that bought it with the farm.
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3533 |
I would at least 'shine' the points up, matchbook cover or similar. They can get a little fuzzy sitting and won't fire.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2276 |
File the points before anything else, add gas and batt., hit starter and go!-- The best way is to pull start them!--- saves the starter and turns the motor faster.
wide
Silver Level Joined: 29 Dec 2018 Location: north iowa Points: 169 |
What gear would you pull start a WD with?
Edited by wide - 07 Mar 2020 at 11:39am |
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2366 |
I use 3rd gear, 1st will prolly just slide the wheels...2nd may do the same...
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5222 |
Don't worry about 'no oil in the base, no 'water in the rad', and that thick 'nest in the air filter' stack. Gary |
Jk chalmers
Orange Level Joined: 19 Apr 2018 Location: Delaware ohio Points: 295 |
Lol good point. All those things and it’ll fire quick I’m sure of it..!! It’s an ac tractor. I had d15 Hadn’t ran in 20 years we had it running in 30 minutes they’re tough little tractors!!
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24092 |
I would change the oil first....at least drain it and check for water in the oil then replace it
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
Oil is cheap, drop the line from the sediment bowl, better yet the carb and let it run. You'll know real quick how bad it is if the gas won't even run from the line.
Let it drain completely so you are not adding gunk to the carb regardless. Touch up the points and would not hurt to check the air cleaner; remove bowl and change oil, ensure clean up to mushroom cap, look up in torque tube if possible for nest at clutch. Pull her in 3rd, or 4th if two Experienced people on both.
If she don't "pop", phase two . . . . .
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4769 |
The WD I purchased last year had not been run since 2004. The date was scribed into the oil filter the day it was changed. Oil looked brand new. It had also received new rear tires. Thankfully the fuel tank and carb had been drained. That was around the time the owner passed away. His wife put many hours on it according to her as she raked a lot of the hay. I put new plugs in, plug wires,points and condenser. Cleaned the carb which was pretty clean. Ended up doing a full carb rebuild due to wear in the butterfly shaft. Runs very well, changed the oil after a few days of test drives. Has run well for over a year now.
AC720Man
Oh, and a new 6v battery.
Post Reply | |
