Torque ?
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: Torque ?
    Posted: 28 Feb 2020 at 3:56pm
Ok 3.5 mph 15.5 cut 4000 lbs same tractor one has a 400 cubic inch (226) 4 cyl the other has a 400 cubic inch( 301) 6 cyl. Figure same cam grind and same compression ratio 2400 rpm on both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 5:53pm
Which one has a bigger carburetor ???   Which one has the cam timing advanced more than the other ??
Edited by DrAllis - 28 Feb 2020 at 5:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 8:18pm
yeah,it ain't that simple
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 7:02am
Which one has tires biting better?  I thought some of the point of speed limit classes was to take the engine out of the equation?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 9:12am
Ok guess its still to broad. Take a 180. For BOTH same tractor for both if i use 301 call it a 180 if i use 226 call it 175 cams ground to same spec set same timing same carburator on both my question is th torq curve on both. As lugging down
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 11:30am
What's bore and stroke on each one?
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 4:10pm
226. Bore 4.6 stroke 6.25. 301 4.25 bor stroke 4.75
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 4:55pm
Generally, it's thought that a 4 cylinder lugs better than a 6 cylinder. In this case I don't know or really care. Even if you have identical everything (carb, ignition timing, compression ((which you didn't mention)), cam grind, cam timing, same exact fuel, same spark plug heat range, same ignition coil, same piston head design, etc, etc, etc...…. You fail to address the fact that one cylinder head may flow air better than the other one  !!!! I prefer to have my engine torque/power and gear ratios such that I don't expect to ever lug one down to a stall or near stall.
Edited by DrAllis - 29 Feb 2020 at 5:01pm
