7G-B track roller questions.
fbbeale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbbeale Quote  Post ReplyReply Direct Link To This Post Topic: 7G-B track roller questions.
    Posted: 28 Feb 2020 at 6:09am
I am looking for either a good used lower track roller or if anyone knows what the aftermarket part numbers are for the bearings, I might try to rebuild it. I only have one that is loose and needs to be rebuilt. Also curious if anyone knows of a good source for the seal kit.
Thanks!
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 8:52am
Do you have the bottom roller parts number and for the boot,spring ass,ring seal and gasket seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbbeale Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 3:43pm
cone 70043491
cup 70659149
seal kit 70078941
All of these appear to be available from minnpar, but I was hoping to see if I could find them for less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 6:21pm
Seal kits are specific for Allis, no one else used them. Berco and the other undercarriage companies supplied rollers with the same style seals but I believe no longer in production by them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbbeale Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 8:59pm
Can anyone tell me what other Allis equipment would have used the same rollers?  Might make it easier for me while looking for used parts.  Thanks!
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 9:12pm
If these are face seals I've been able to get them here in Oz for the carrier rollers of an FA 10 using the Fiat part numbers.  So maybe able to find something that way?
Seems our access to Fiat dozer parts is better than yours though - for reasons I don't understand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 8:00am
I have no more complet seal kit but have some boots,springs assembly,gasket seal ring and ring seals.
                                        HECTOR
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 8:02am
Morning, or Evening Ian. These should be same as my 7G or 11B series rollers, use the bladder type steel ring seals. Looked in my Timken Cross reference, No interchange for Allis numbers.
I will be removing the old rollers from my donor tractor this next week, most are trashed as flanges are almost gone, can pull one down to see what numbers are in it but will be a few days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fbbeale Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 10:39pm
So I think I have located a decent used roller, but in the process of searching I discovered that my loader appears to have some rollers that are the original style with two blocks that sandwich the shaft on each end, and I have some that appear to have a solid steel block that slides over the end of the shaft.  The ones with the solid steel blocks have a slightly larger diameter shaft than the original rollers.  I may need to locate the mounting blocks for the original style as the roller I am replacing is the larger type and the supplier of the used roller isn't sure if they have the blocks.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2020 at 8:38am
Blocks from HD11 rollers would work too.  There were several variations of the rollers for these tractors, including bushing style rollers instead of bearings, starting in the late 70s.
