636 Allis Chalmers crusher
digr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote digr Quote  Post ReplyReply Direct Link To This Post Topic: 636 Allis Chalmers crusher
    Posted: 26 Feb 2020 at 7:43pm
Hi all I am new here and hope you can help me, I am looking for a head nut for a 636r Allis cone crusher. Any help would be appreciated.
Thank's    Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 10:57pm
Welcome to the forum. Pictures and part numbers might help.
digr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote digr Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 7:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 8:41am
Locking nut assembly for a cone crusher
Abstract
A two-piece locking nut assembly for securing a mantle to a head assembly of a cone crusher. The two-piece locking nut assembly includes an inner nut and an outer nut. The inner nut includes a set of axial bores that each receive a jackscrew. Once the locking nut assembly is in position on the head assembly, the series of jackscrews are tightened to exert a force on the mantle that is counteracted by forces through the inner nut and into the head to create a locking force between the locking nut assembly and the head assembly. The outer nut is turned along the inner nut to hold the locking nut assembly in place. Once the outer nut is moved into position, the jackscrews are removed such that the outer nut continues to apply the locking force between the mantle and the head through the locking nut assembly.
Images (9)
<-carousel id="figures" ="style-scope patent-result" style="display: block; : rgb239, 239, 239;">
Classifications
 F16B39/12 Locking of screws, bolts or nuts in which the locking takes place after screwing down by means of locknuts
View 4 more classifications
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 8:44am
No longer supported by Svedela or excel foundry?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 8:48am
digr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote digr Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 6:13pm
Thanks everyone Metso found what I needed
