190XT splitting stand
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT splitting stand
    Posted: 26 Feb 2020 at 11:06am
I am looking for advice on what to do about a splitting stand for my 190xt. I will be splitting it at the rear of the torque tube/front of the transmission my plan is to roll the rear of the reactor back with the rear wheels on. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 11:30am
Any chance you've got an overhead steel I beam ?  That makes it easy, well, easier....
Put tractor under beam, parallel to beam. Use chain hoists to lift then use solid wook blocking. When rolling rear, 1 guy per wheel, otherwise it'll go 'funny'...
Be sure to block the steeringtierod ends !
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 2:44pm
For the front end which you are not moving block each side by the front axle pivot so the motor doesn't tip then support under the bell housing using blocks with a jack or we used a screw jack so you can adjust when removing and installing. next you have to support the platform that is where the overhead works the best then you loosen the rear from the front I believe the rear end when rolled back is heavy to the back we put a floor jack under the back drawbar, I would put blocks in front and behind it so it can't tip either way. If you are good with some angle iron and tubing and threaded rod and some wheels you could make something up. Just depends on what you bolt to to do a complete tear down. In the end you you have to support the housing. Just to give you some idea when I rolled the front away on the 200 to work on the motor we used the cherry picker to support it then i needed the cherry picker to remove the motor so to support the front away from the tractor two 2x4s drilled holes and bolted to the ends of the frame rails  fast simple cheap stands.
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 3:31pm
I cut most of the parts out for some a few years ago to build one of these.
It is two parts, with four jacks.
I don't know if he very got it made.
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 8:59pm
That looks identical to the splitting stands used when I worked for john deere. Not familiar with a 190 but if there are any places you could bolt plate steel to and weld a wheeled jack to the plate that works real slick to. On the deeres you could either use the pictured splitting stand on the rear and plate jacks on the front or block the rear and plate jack the front and roll it away
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 8:23am
   I used two leveling jacks for scaffolding then welded swiveling heavy duty wheels on the bottom. Found a length of pipe to slip over so they are adjustable, welded pipe to angle iron for bolting to side rails, drill out hole for another angle iron to brace it at a 45 to the front of side rail. Get another angle to tie the bottom of jacks together under the tractor, welded some tabs on and bolted them together. Worked great on 7000and 8000 tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 8:42am
   I reread you post, why roll the rear end of the tractor? Its much easier to roll the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 9:15am
 The whole front of the tractor and the platform are together it is easier to just support that and not move it and just roll the rearend end out. He wants to work on the transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 9:28am
Got ya, have the 8000 on my mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 10:13am
For a one-time split, you don't need much. Block both front wheels front & back so it cannot roll. Block the front axle so it cannot pivot one bit left or right. A  trusted/no leak down bottle jack (or a screw jack) placed on top of a tall solid base underneath the torque housing right close to where you intend to split the tractor. A short 2 x 4 between the bottle jack nose and the torque tube would be smart. Your biggest issue is raising the platform and holding it up so you can roll the rear end away.  Once the rear end is rolled 10 ft back, you'll need to raise it up and block it so the rear wheels are off the ground 3 inches. When rolling the rear end away, an 1 3/8" pipe four feet long stuck on the PTO shaft is your good way to control the whole assembly. One man on each rear wheel and one man on the pipe.
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 11:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 11:29pm
I have split three 190's a "B" and a WC with these stands. work like a dream, safe, easy one man job.
