HD16-DP front grill
MIkeO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIkeO Quote  Post ReplyReply Direct Link To This Post Topic: HD16-DP front grill
    Posted: 22 Feb 2020 at 7:29pm
Evening
got my hd16 a couple years, somewhere along the way the front grill  had gotten pretty beat/bent up, welded, re-enforced....  its really hard to get it back on now(had taken it off to replace the hydraulic hoses)  So was wondering if anyone knew of one by chance.  Other thought was trying to make a template  and cut one out.
On another note, I screwed up when I was lowering the front and  popped the radiator collar off.  Its a little bent but think I can get it back in round so the cap will fit again. If not would a heavy equipment  shop most likely be able to order one?  and I can solder it back on.  Speaking of radiator just curious if i wanted to just replace it is the best solution just to get it cored or does some other radiator fit it by chance
thanks
Mike
This page was generated in 0.044 seconds.
