What can a WD45 do that a WD can't?
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Topic: What can a WD45 do that a WD can't?
    Posted: 21 Feb 2020 at 9:12pm
What's the difference in power between the WD and WD45?
 What implements can a 45 use that would drag a WD down?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2020 at 9:14pm
One more bottom on the plow and/or a gear faster
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2020 at 9:49pm
I always used to say a good WD45 would start out with a load of hay or corn in 4th gear. A WD would get it rolling in 3rd and then shift into 4th.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 7:34am
And....al the later WD-45s had the 3 disc hand clutch to help get that job done.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 7:51am
WD45 will burn more gas.I always preferred the gearing in a WD
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 3:16pm
About everything. Dad had a new WD with a 2 row AC planter. It was traded for a new wd45. Dad never liked the WD. Dad continued to farm for 50 more years. He always said the 45 was his favorite tractor. That is one of the reasons we still have it. Even though he purchased a new D17 in 1959, he continued to plant, seed, harrow make hay, etc with the 45. I do know from experience the 45 would out run the 17 going down the road.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 5:20pm
Out pull, out push and out run the WD.  Where I farmed, the WD would pull a two bottom and the 45 could pull a 4.  Going down the road in the 45 in 4th gear was pure pleasure.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 5:37pm
Dad grew up first on a DC Case, then when living with his step uncle an IH M, a new Super M and a new Super C. When he was 18 he left and later after marrying Mom, he bought a VAC from his Dad, who had an independent shop and sold some used tractors. Then Dad got a WC due to Mom's family influence, then a WD but it was when he bought a WD45 that he was fully converted to Allis. That was back in the late 1960's.
Dad has always said nothing he hooked to the 45 could stop it. The family has been Allis ever since. Wish I had that 45 today.
Wink
I am a Russian Bot
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 5:53pm
How much of a difference is there between a '45 and a gas D-17? That's where we saw the 2-4 bottom difference(WD-D17).The '45's "here" could only pull 3 bottoms.
Edited by FREEDGUY - 22 Feb 2020 at 5:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 8:09pm
Three tractors in the same field on the same day all mounted/semi-mounted AC plows with identical plow bottoms. WD with 2 x 16's or 3 x 14's.   WD45 with 3 x 14's or 3 x 16's.  D-17 3 x 16's or 4 x 14's.  In fields where WD-45's can pull 4 x 14's a D-17 should pull 4 x 16's or 5 x 14's as they claimed in their early advertising literature.  They didn't stick with that claim very long and the best plowing D-17's would be a series 2 or 3. Series 4's were 4 HP short and series ones (unless updated) had a Traction Booster that didn't work as well as series 2's and 3's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 1:28am
Dr Allis I never knew that about the D17s. The D17 diesel I got off Allen R would pull a 3x16 plow in corn stalks in high side of 3rd gear. I did it 1 time, threw the dirt clear out of the furrow.   I hope Allen doesn't turn the pump back down.
Edited by HD6GTOM - 23 Feb 2020 at 1:29am
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 6:43am
Bottom line is the WD-45 had more power and if the tractor is weighted do get the most traction it would out pull the WD.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 7:02am
WD seemed to be geared slower so weighted the same the pulling power might be the same in a given gear but the WD would be slower,sort of like the RC and the WC.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 7:46am
So many early WD's only had 12.4 x 28 rear tires with 10 inch rims and so many more later WD45's had the optional 14.9 x 28 rear tires with 12 inch rims.  That in itself added speed, weight and more traction to the 45's to better utilize the "bang" of the modern "Power Crater" combustion engine !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 2:27pm
When my 45 had 7.25: 1 M&W's and a 175 cam,it was very happy with a 4-16 semi mount 70 series plow in 2nd gear. Couldn't quite hack 4-14 in 3rd so I spread it out and dropped a gear. After the crank pulley got loose and the crank got cracked,I rebuilt it with new crank and Sealed Power sleeves/pistons which are M&W design but stock compression. You can tell it's got less.The 220 and 9 shank Soil Saver took over tillage so the 45 is now a loafer,but I still love it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 4:43pm
We pull a 4-14" plow behind a 45, I'll put that on the WD this year and see how it goes!
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 4:46pm
The legit M & W  (SP-48 motor kit ?) 4 1/8" bore pistons were 7.4 to 1 compression ratio, just a tad higher than the 7.25 to 1 of an OEM D-17 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2020 at 7:20pm
Well that's what they were then....have that number inside....installed about 1982...have em in a box. They are scored some and ring lands have wear.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 8:32am
When Dad stopped farming in 1967, the WD didn't do much tillage work anymore.  It still pulled the JD 495A planter in the spring, had a the four -row front mounted cultivator in the summer, and pulled a flare-bed wagon with hoist in the fall.  Heavier work was done with a JD 720 diesel, JD 70 gas, and the WD-45 I still have.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 10:13am
I use both here and don't see any difference in them. The good 45 only pulls the snap-coupler 3x14 plow in first gear and will kill the engine IF I am not quick on the clutch. This is some tuff ground so I never tried the 4x14 semi-mount that I have for it.
The good wd gets the 6' KK tiller duty. --- runs too fast but a couple three passes and its not too bad. It also gets the Woods C-80 to chop sweet corn stalks----makes quick work of that job. --- Lot's faster that the C and a 59 mower!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 5:26pm
Dad pulled a 2/16 fully mounted plow with a WD, and pulled a semi-mount (snap coupler of course) 4/16 with a series 2 D-17. Our next door/farm over neighbor ran an Ford 801 Selecto-Speed and a WD 45 that he could only pull a 3/16 "mounted" plow slower than the '17 30' across the fence line?? Perhaps the semi-mount makes a difference??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 5:49pm
Maybe he was plowing 1 inch deeper ? or didn't know how to fully use the Traction Booster... Semi mount is longer and should pull harder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 6:07pm
Now that you bring up the T/B, did a WD/WD45 have that feature? I distinctly recall the notched "under" lever underneath the main hydraulic lever on the '17, but seems like our WD only had a single hydraulic lever Ermm .
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 6:35pm
Yes all WD's and WD45's along with all CA's had Traction Booster using the same lever that raises the hitch. Adjustments at the pump determine in what manner the hydraulics work depending on what you want to do.
Wink
I am a Russian Bot
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 9:54pm
I'm in agreement with ac fleet. Have both myself and don't see much difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 11:07pm
Trying to go only an inch deeper can be a deal breaker !! LOL! There's night and day between 6&8 inches.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 8:32am
We went from a WD to a WD45 diesel and when you did that in the 50's; you never even thought about a WD again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 8:38am
Any of the posters who say they see little difference between a WD and a WD45, especially when it came to plowing, don't realize that MANY WD's got a HP uprate at overhaul time, making them closer to a WD45. Unless they are the original owner and actually know if this did or did not happen, it is total speculation on my part. The WD was 34 HP and many were uprated with M&W pistons and sleeves to 40 HP. The WD45 was 43 HP from the factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 8:48am
WD:      34.63 Belt/30.23 Drawbar
WD-45  43.21 Belt/37.84 Drawbar
If both tractors are in equally good operating condition, that 25% increase
is certainly noticeable!
D-17      52.7 PTO/48.64 Drawbar
Then.....the 28.5% increase of the D-17 over the WD-45 is pretty
darn noticeable too.
I have a WD with the 1/8" overbore kit and the WD-45 will still run all over it.
My D-17 is a whole 'nuther world!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 10:28am
Dad always claimed that his 45 could keep pace with the D17...... he never owned both at the same time though as the 45 was traded for the 17................. Come to think of it I think he had his 45 overhauled at one point with bigger pistons so probably had more than stock hp.
Wink
I am a Russian Bot
