|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Diesel Injector Tester |
| Post Reply   |
| Amos   Orange Level   Joined: 11 Sep 2009 Location: Ontario Points: 1318 |  Post Options  Thanks(0)  Quote  Reply  Topic: Diesel Injector Tester Posted: 20 Feb 2020 at 10:42am |
   Can some one with knowledge about these tell me what is the in and out of them.  I see a bunch of what I think are chinese ones out there for sale but I see also an OTC one that seems really expensive and one made by Klein, but then I am assuming that there are different adapters for the different types of injectors.  Just trying to get a feel for what is a good one and what if any are better than the other ones.  Do they wear out over time and need repair and if so what ones can you find parts for?
 Edited by Amos - 20 Feb 2020 at 10:43am | |
| Boss Man   Orange Level   Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Feb 2020 at 4:52pm |
   The 2 places I worked had OTC's. Think the one at tech school was OTC as well. Its basically just a diesel fuel pump with a gauge on it that tells you at what pressure the injector opened. It has a plunger with a seal on it that can wear with time. We had about 6 different lines that we used depending on the injector.
| Acdiesel   Orange Level     Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2578 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Feb 2020 at 6:25pm |
   i have an OTC, is been a good unit. In my opinion when it comes to tools like this you get what you pay for. Dan
     D19 Diesel,D17 Diesel SER.3  2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) | |
| SteveM C/IL   Orange Level Access   Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8678 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Feb 2020 at 10:33pm |
   My diesel guy is only 10 miles away....no way I'm messing with it
| Amos   Orange Level   Joined: 11 Sep 2009 Location: Ontario Points: 1318 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Feb 2020 at 6:30am |
   I completely understand you Steve...but I have been getting terrible workmanship from both the shops 60 miles from me, they are the closest I have.  What I have a problem with, is I didn't used to get that kind of workmanship from them, and the bill for each job they did is, well lets say I can buy the new OTC machine and the set of adapters for it for the price of the last two injector jobs they did for me, and then I had to take them back, a couple times ad listen to how I put the engine together wrong, but when I got the injectors and pump back from them the second time, low and behold they engine ran right.
| injpumpEd   Orange Level Access     Joined: 13 Sep 2009 Location: Walnut IL Points: 5122 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Feb 2020 at 7:24am |
   I have several various testers. The best bang for the buck, and ebay availability, is the little OTC 4205, also marketed for Ford dealers saying Rotunda. You'll need an adapter kit, and texas parts has a nice set, unless you find the bacharach set, which should have the 9/16 X 18 ermeto which is what the AC injectors, and many other older tractors used. The other popular connections are 12mm X 1.5 and 14mm X 1.5. Pencil injectors also have unique adapter requirements. The bigger OTC 4200 is my main tester, and also sold through Cat dealers, but it's more expensive. Now, there's a lot more to rebuilding injectors than having a pop tester lol!
| Amos   Orange Level   Joined: 11 Sep 2009 Location: Ontario Points: 1318 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Feb 2020 at 10:26am |
   Thank you Ed.   I am not really looking to rebuild them, just to find out what is going on, be it right or wrong with them.  If you know what I mean. | |
| SteveM C/IL   Orange Level Access   Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8678 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Feb 2020 at 11:52am |
 I understand Amos. My past mechanical Cat had issues after a certified dealer put injectors in it.I ended up getting a manual and some Cat pump tools and fixing their screw up. It was a dog after they fixed it. They claimed new nozzles weren't dumping excess fuel so that's why. Turns out mechanic didn't set AFR control correctly after putting new diaphragm in. Book tells procedure and he didn't follow it....I watched him. To a while to figure it out and correct but ran GREAT afterward. | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
