Wire crimping tool
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Wire crimping tool
    Posted: 19 Feb 2020 at 9:11pm
Every now and then i have the need to put a terminal on the end of a 6 gauge - 0 gauge wire.  Normally i solder, or set on the vice and punch it a couple times with a cold chisel .. Got to wondering what they have on e-bay or similar.
Found this.. about 16 inches long and HEAD rotates to several different sizes from 8 gauge up to 0 or so... It appears it compresses to a HEX about 1/2 inch wide... anyone have one or use one of these. ?  Price is about $20. .......... have also seen a version that is a block with a PUNCH that you set on the table, then PUNCH the  set to put a dent or two into the terminal..... similar to what i do with chisle ............. seems like the hand held might not deform ( bend) the terminal as much ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 4:45am
For what its worth, I have the little hammer block one, it does alright.  The rebuilder that I have locally, uses one like the one shown.  It takes less time to use the one shown...Wink
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 4:57am
I have a hydraulic crimper that I purchased at Harbor freight. Has several sets of dies and works very well. I think it goes up to 2 guage.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 5:03am
My opinion only. Buy the tool you've shown. It will do a good job, especially,if you will only use it occasionally. If you need something for daily use, look for a similar major brand tool.
Edited by Bob D. (La) - 20 Feb 2020 at 5:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 5:26am
Heck I'd buy one for $20, kind of a nobrainer. It'll pay for itself the FIRST time you use it,after that, every crimp is free !
To use though, I'd slide some heat shrink on first, crimp, solder, then pull the HS down and heat. Spending an extra 5 minutes NOW doing it right and proper saves you 2 hours of grief and frustration later.....
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 5:09pm
Steve, I've been around that lever style crimper and the type that you strike with a hammer for 40+ years ( 1975). The ones ( for a #8 gauge to 4/0 gauge copper cable )  I priced was over $40 for hammer style and lever type ( as in your picture )was almost $200. They always worked fine for us, you will need to make sure the ends you use are "CRIMPABLE" , the larger ends from #8 thru 4/0 come in; crimpable , combination (crimp or solder), solder and a couple suppliers have what they call " LOADED" these solder type and are pre-filled with solder. Make sure to use heat shrink to seal connection.
We kept the lever type in the parts department, I owned and carried the hammer type in the service truck for repairing cables on service calls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 7:07pm
I have one similar I got about 5 years back for crimping feed cables for snow plow electric cable repair . Then since buying it havent had any problems since i changed the brand of plows I have
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 7:33pm
See Coke, it does so good you don't even have to use it for it to work. LOL I have about the same thing, bought a tool because I didn't have one when I needed it and then never need it again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 7:44pm
Saw the Namebrand on e-bay for $200. as you said....... Several "brands" of this model for $20-25.  they all appear to come from the same china factory with a different name on the head.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 8:07pm
I bet if you use the copper crimp ends those will last forever, if you were using the metal crimp ends maybe not, but for $20 it's no big lose if they fail.  I use the hammer style but when I worked in a shop in college they had a set like those and  I always felt they did a better job, however I haven't had the hammer style come loose or fail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2020 at 9:22pm
I always just used my big vise. no one around here had a crimper like what was pictured above, if I was still doing more stuff i'd buy that crimper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 6:15pm
BTDT! I hadn't worked the machine repair job too long and had borrowed a snap ring pliers a couple times. Bought a good set from the MAC guy and didn't use them for over 2 yearsShocked
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2020 at 8:42pm
Ive got one of these
ebay link
Ive used it from 6 [had to make a smaller die than what comes with it] all the way to 2/0. Im really pleased with it. Wish i had bought it sooner. Have never had a problem with it or the job its done so far
