D19 gas fuel pump
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Topic: D19 gas fuel pump
    Posted: 13 Feb 2020 at 7:17am
Does anybody know what pressure the d19 gas fuel pump roughly had, going to put an electric one on so wondering what kind of pressure is needed.
Tim_Gorge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim_Gorge Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 7:52am
The D19 is gravity fed. Don't know why some one would have put a pump on it.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 7:58am
they come from factory with mechanical pump run off the camshaft
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 8:00am
There is a repair kit available for the original fuel pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 8:07am
It doesn't take very much pressure to keep up with the engines fuel demand. 5 psi would be plenty @ at least a 6 Gallons per hour delivery rate.
Rhoadesy_65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rhoadesy_65 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 8:27am
agco parts book shows two different serial number ranges for the pumps
Also found a new fuel pump that claims to be for d19
Edited by Rhoadesy_65 - 13 Feb 2020 at 8:27am
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim_Gorge Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 9:32am
Learn something new everyday should have kept my mouth shut. Now you guys have me going through my manual I've done some extensive repairs on d series and been around them my 34 years and have never ran into this never had an issue. I love learning. Sorry fir the waste of space on your post... good luck.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 10:35am
I've got a customers's D19 in the shop now that is former LP converted to gas.  LP tank is being used for gas and is gravity feed to carb. The fuel pump mount still has a block off plate.  Seems to run just fine so far.  It's in for leaking head gasket replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 10:55am
It will run just fine until the engine is under full load for more than 2 minutes or the tank gets low on fuel and there's not enough gravity pressure to keep up to the engine demand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 8:13pm
I'll talk to my customer about this. This is a tractor that they have had since new.  It was retired but now is going back to work.  They did the conversion from LP to gas, but haven't really worked the tractor yet.  Now would be the time to install a fuel pump while it's in the shop.
1852 Moore Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1852 Moore Farm Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 9:06pm
Our 19 is gravity fed. It seems to drink the gas just fine. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 11:52pm
Thanks for the replies, the tractor I have is a d17 diesel chassis that's got a g230 gas in it, it didn't have a pump on it when I got so I bought a aftermarket one that was junk from day one so I unhooked it and ran line from tank to carburator but acts like it runs out of gas at times so going to try a electric one and see how it works, found one that runs 4 to 5 psi so going to try that.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 5:47am
I have an electric pump on my D19 because the original went bad and couldn't find a reasonable priced replacement.Got a pump with max pressure at 4lbs still  flooded the carb.So I put a T in the line over near the carb,ran the one line back under the hood
up near the top of the gas tank and back down to where the line comes out the tank before it gets to the pump.So now the max pressure is the fall from the top of the tank
to the carb but the fuel pump keeps gas flowing.End result is the tractor runs without flooding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 7:48am
do you have the part number for the repair kit? mine is gravity fed at the moment the original pump is dried out from sitting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2020 at 7:10am
Fuel pump part number is 74055537v
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 28 minutes ago at 12:10pm
I just wanted to let everyone know that 74055537v is no longer available.
If you choose not to decide you still have made a choice.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 17 minutes ago at 1:21pm
24s mr gasket pump i think it is 4-6 psi
