WC shifter issues
68mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68mustang Quote  Post ReplyReply Direct Link To This Post Topic: WC shifter issues
    Posted: 11 Feb 2020 at 9:21pm
Replaced shifter lever pin with oversized , shifter housing was removed and all went back together ok
Know shifting with tractor not running seems like I can’t get it into 3 gear..
Did remove the whole shifter housing to check the lower part of the shifter, reverse latch also in place.
Haven’t tried to shift with tractor running yet the gas tank is out.
Edited by 68mustang - 12 Feb 2020 at 4:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 9:27pm
If gear teeth are not lined up, they won't go in gear.        MACK
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 8:32am
Mack is right.  If the gears aren't lined up, they will hit each other and not slide in.  Try engaging the belt pulley, lock out the clutch, and give the input shaft a wiggle with the belt pulley.  Bet it'll drop in.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68mustang Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 9:42am
You mean try to turn the engine over some, correct, 1st gear and 2nd shift smooth.
Reverse can’t tell if it’s reverse or 4 th.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 12:52pm
Not the engine, just the tranny.  If you lock the clutch down and engage the belt pulley, you can spin the transmission input shaft and see if 3rd will drop in.  If you don't have a belt pulley, you can do the same with the PTO and a pipe wrench.  Just make darn sure your clutch is locked down and its in neutral.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68mustang Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 3:42pm
Aron thanks , did exactly what you said, think I’m getting all the gears.[
Edited by 68mustang - 13 Feb 2020 at 2:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68mustang Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 3:48pm
thanks Mack you guys are great, I engaged the side pulley to spin the transmission with clutch engaged always when working on the tractor , then tried shifting gears and think I’m  getting all the gears .
Thanks
This page was generated in 0.099 seconds.
