Wd 45 shifter handle |
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Topic: Wd 45 shifter handlePosted: 06 Feb 2020 at 6:56pm |
Who makes the best quality shifter handles? I see a lot out there available and I wanted to get some opinions. This one has been repaired several times, guess it should be replaced.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 07 Feb 2020 at 6:21am |
I would guess that every aftermarket company that sells them is selling the exact same one from the same machine shop. AaronSEIA
HD6GTOM
Posted: 07 Feb 2020 at 9:19am |
I got one from an after market company, it did not have the knob on the end of it to hold the rubber knob on. If I were to buy another it would come from Sandy Lake.
DrAllis
Posted: 07 Feb 2020 at 10:47am |
30 or more years ago, a new gearshift from AGCO for a WD/WD45 required a new large plastic knob like later 185's and 200's. The shift lever itself was probably 5/8" diameter all the way from the shift boot to the new plastic knob, not tapered like the original. It was obvious they had a new vendor and they made them for all orange tractors at that time in history.
AaronSEIA
Posted: 07 Feb 2020 at 1:03pm |
The one DJS shows in their catalog has a taper at the end and the ball for the rubber knob. AaronSEIA
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 07 Feb 2020 at 2:09pm |
I have one on my WD like DrAllis descibed. Bought it in the early 1990's from AGCO. I just welded the correct bolt on the end so the old knob would screw on. I ground the weld down so you can't tell and only a watchful eye will see the thicker diameter shifter.
Wink I am a Russian Bot |
Lonn
Posted: 07 Feb 2020 at 2:10pm |
I have a new one for a WD45 somewhere that I bought when I bought my WD one.
allisbred
Posted: 08 Feb 2020 at 4:11am |
Lonn, If you want to let it go, let me know. Think I’ll call Sandy Lake and see if what they have are shaped the same, I am more concerned of the key ways and machining quality on the lower end. Most after market stuff in the past I have been disappointed with. Thanks for your suggestions! Kevin
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11416 |
Posted: 08 Feb 2020 at 11:59am |
Look to see what Steiner Tractor Parts out of Michigan has.
