All is chalmers DD grader, diesel pump timing help
Westlakes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Westlakes Quote  Post ReplyReply Direct Link To This Post Topic: All is chalmers DD grader, diesel pump timing help
    Posted: 04 Feb 2020 at 2:23am
Our car club at Awaba NSW Australia has an Oz built Allis Chalmers dd grader. We have had the roosa master pump serviced, but part of our diagnosos we removed the timing cover and have lost any reference to where the pump timing gear engages. Any help tracking down a manual or where to find the pump gear timing reference marks would be greatly appreciated.
Looking over here and other forums the oz manufactured grader may have the 262 6cyl diesel. The timing dot on the pump gear shaft and the roosa master timing window have been pointed out to us.Not sure if it is as simple as lining up TDC and installing the pump gear so all the alignment marks on the pump are true or do we have to install the gear and pump at a timing reference before TDC ?
Edited by Westlakes - 04 Feb 2020 at 5:27am
David88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David88 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 1:50am
hahaha this is my second reference to the same manual, guess the guy's having a good day.
try reliable-store it is best.. my hyd oil had been leaking and I find random ways to fix it, and the actual solution in the book was actually game!!!! all the best brother
This page was generated in 0.721 seconds.
