D 17 Rear Wt Question
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: D 17 Rear Wt Question
    Posted: 18 Aug 2010 at 8:17pm
I have a D 17 SIII sith differendt concentrics than on the 45 etc. I have AC wts but when I line up the notches to match the concentric, the bolt holes don't match the center. If I match the holes then I won't be able to get at the bolt to change PAW. Does the S III only take pie wts for all to work ? I notice on the 45 the concentric is outside the weight and no need to match notches at all. What are the notches and slots for anyway. The big 2 slots make them easier to carry - that the purpose ? What am I missing here ? Thanks, Larry Miller
I used to be young and stupid, now I am not young anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 11:35am
No one had this problem ? I think the only thing I can do is drill holes in the wheel center if I want to use these weights and be able to adjust the PAW without removing them.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 12:13pm
I have AC weights on my 17 but it's a series I. No problems.
Wink
I am a Russian Bot
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 4:20pm
prolly takes a pie weight
BobH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 5:40pm
I put WD45 rear weights on my 1962 D17D,they fit OK.
