Removing Fuel Line Clamps ?? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Removing Fuel Line Clamps ??Posted: 02 Feb 2020 at 5:19pm |
How do you remove the clamps with a blue colored plastic ring off of the fuel lines on an in-line/rail mounted fuel filter on an '05 Ford F250 ? The lines will swivel on either end of the filter, but I can't figure out how to release the "clamp" . Whatever happened to the old style SS clamps that required a flat blade screwdriver;5/16 nut driver?? If I cut the "clamps off, the lines will be too short BTW :-( Thanks
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 02 Feb 2020 at 5:52pm |
[TUBE]Boi0DPXVHbM[/TUBE]
FREEDGUY
Posted: 02 Feb 2020 at 6:26pm |
Thanks for the video, but those aren't the style of clamp that I'm up against, no metal banding involved.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4939 |
Posted: 02 Feb 2020 at 6:49pm |
sounds like these - [TUBE]u91wzxa0xjg[/TUBE]
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 04 Feb 2020 at 6:17pm |
GM uses then as does Dodge - there is a small plastic u shaped clip you push the one part forward and it releases the inner clamp - there are 2 O rings inside of the inner part
I got mine lose with a screwdriver pushing the inner part and when I bought some new fillings it had the little tool included . I had to replace 2 lines from fuel pump . Check some filters might include the tool Edited by Coke-in-MN - 04 Feb 2020 at 6:21pm |
FREEDGUY
Posted: 04 Feb 2020 at 6:24pm |
Thanks Coke :-)
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 05 Feb 2020 at 8:50pm |
There is a special tool that you can get but they can be pried up with a flat screwdriver on the side with the big tab. Positive locking tab doesn't come apart to cause a fuel leak, band clamps can loosen/rust/slip off especially if rubber lines rot also.
FREEDGUY
Posted: 06 Feb 2020 at 5:03pm |
Thanks Bill,waiting for another warmish/dry day to crawl back under to take things apart :-[
Coke-in-MN
Posted: 06 Feb 2020 at 6:29pm |
I started chasing rusty lines on my 2000 GMC - ended all the way back at the lines coming off the fuel pump - I bought 1 line that had a 90 deg bend from NAPA - cost $17 , next line i needed when another leak developed I bought from Oriley Auto - $6 for a 12" line with the swedge on each end , then a package of the plastic clips for $4 which had a small plastic tool included to remove the lines .
Many of the replacement, GM / Chrysler Corp, filters now on cars are also using the push in clips to hold them . I fought with the dang thing and said quite a few words before son showed me how to release the clip without the tool. Dang modern inventions - but as new fuel pumps put out over 60 PSI guess our old ways of doing things needed a update That 12" line I cut a piece off as it was used on return side , now I have the extra 6" in the cabinet if needed in the future - that along with 3 extra clips Edited by Coke-in-MN - 06 Feb 2020 at 6:32pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4071 |
Posted: 07 Feb 2020 at 7:52pm |
glad you mentioned the higher preasures because 60psi and any kind of leak = fire the right hoses and fittings required
Coke-in-MN
Posted: 07 Feb 2020 at 8:08pm |
Two seapareate types of hose so if you replace any of the metal lines with hose be sure to use the right hose type - high pressure hose is marked as such and is a lot more in cost than just fuel resistant hose we use to use or that is used on return side fuel line
FREEDGUY
Posted: 08 Feb 2020 at 4:35pm |
Now that you brought up the PSI issue, I run air hoses off of a compressor that is putting out 100-110 PSI with the old school hose clamps on repair sections and don't have any issues with leaking ?? |
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10406 |
Posted: 08 Feb 2020 at 9:03pm |
Rather than using hose clamps, use PEX rings. Neighbor did this for some water hoses and air hoses. Works great and no cutting hands on the clamp.
