GM NP 246 transfer case
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: GM NP 246 transfer case
    Posted: 02 Feb 2020 at 12:05pm
Well the saga continues - bought a used case - again said it worked - NOPE ground like mad when power applied - no link between transmission and main shaft output-
opened it up and the spline coupler that engages the inside of planetary not sliding into unit .
 So 3rd case setting in shop - truck up on jackstands - and my patience being tested on this full snow plowing thing .
  So ordered a set of clutch discs , bearing and seal for my original case from truck - put in 10 new friction discs - 10 new steel discs and spacer shim from the clutch pack . Old clutch stack had 10 friction and 9 steel in it but that seemed lose so added the 10th steel . Is back in but have shafts and actuator to hook up yet .
 Today project after i finish my coffee or ???
So clutch pack was $60 for the set here from local auto supply discount store down in St Paul Park . They dont have a service counter , or ask you a bunch of questions and many times just tell you go into back room in row 4 shelf in center and get what you need - here is part number (written on scrap of paper )  seems they have a discount system also for cash - rounded off price
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 7:28pm
The MN Fentanyl connection. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 11:48am
Well spent Sunday afternoon and night finishing the job , yesterday picked up the tools and drove the truck out of shop in 2 WD - tried going up hill in yard - spun rear tires - put it into 4 WD climbed up ice easily , tried 4 WD Autotrack - works there also .
 So the easy repair only took 2 weeks to do what I should have done the first time i had problems , replace clutch pack in case, could have done it i n2 days if I would have just worked on it.
 So now have 2 extra transfer cases one for parts and one used good unit but for later model GM units .
 Now if someone needs a NP 246 transfer case for 2004 or later with the round splined input shaft or actuator motors for either type early or late - I have them for sale .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 11:59am
got ANY hair left ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 12:07pm
Now it ain't gonna snow. Wink
Glad to hear you got it going good, you'll need it for other things too.
