Whopping price for a 2900 engine
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: Whopping price for a 2900 engine
    Posted: 02 Feb 2020 at 9:28am
I just saw this on Ebay and thought one of you guys might be interested. You may be able to negotiate the price a little....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 10:00am
and.....
YOU have to remove from combine !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 10:02am
Appears to be a "G" Gleaner combine engine by the old TO-4 turbo V-clamp type compressor housing.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 10:06am
From the listing:
“ Shock price because they charge an arm and a leg for promoted listings, so this makes it cheap advertising ;) Please come check them out or make a reasonable offer on one or both.”
This seller won’t last long on Ebay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 10:16am
His idea worked. It shocked me !!!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 5:28pm
That's a Thompson turbo. A TO-4 is an Air Research
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 5:31pm
I'm afraid not. That is an old TO-4 48 like the later 190XT's had. In 1972 the 200 tractors got the TO-4 B-series which didn't use the V-clamp. That isn't a Thompson.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 9:25pm
Air research.       MACk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 2:27pm
You need to look at the pictures in the parts book. The TO4 looks totally different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 4:01pm
Look under the 190XT parts book and you will see at eng s/n 30,000 something they went to the first generation Air Research TO-4 series. There is also a picture of the Thompson, which later became RaJay. The oil drain line connection is completely different between the two turbos.  Look at the turbo for a 200 or newer and it again is different because it is the second generation of the TO-4 series.
8070220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070220 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 7:38pm
It a g and yes it is a to4b .like dr said.
