JB WELD
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Topic: JB WELD
    Posted: 02 Feb 2020 at 5:13am
A few weeks ago there was a discussion about JB Weld. Someone thought that another product like it was as good or better. Dose anyone remember the name of it?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 6:21am
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 10:04am
  I've used both and have good luck with Belzona as it is easier to machine. They both have a temperature limitation fo bout 500°.  There is a JB weld "extreme heat" that is good to upwards of 2000°,,,!!! It must be special order stuff as I've never seen any around here..
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 12:19am
don't Permatex make something like that too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 1:49am
 I have not ever seen any Permatex product but there sure might be,,,,actually,,,if you needin some patch material for where you need some heat tolerance,,,the JB Weld Extreme heat looks like the best,,,,,
  HMMmm,,,gonna check out Amazon see what they got,,,,
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 9:25am
All depends on want u are using for.
nonetheless ,still dead.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 12:37pm
Dog gone it, I have never seen anything of these products, except plain old JB Weld. Guess I'll have to ask next time I'm at NAPA.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 3:19pm
I have used PC7 it works and comes in 2 parts and you mix them together, it's solider and used it on sand stone monuments so it takes all kinds of weather. When I used JB Weld it wouldn't take the freezing weather
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 4:06pm
I have used PC7 also. Good stuff Maynard.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 8:20pm
Sorry to hijack but, chaskaduo, where is the Maynard from?  I've heard and said that for as long as I can remember but don't know origin.
Oh, and I have used Lab Metal from Fastenal as a filler, not an adhesive.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 9:32pm
Gonna take a stab in the dark and say it's a reference to Maynard G. Krebs from Dobie Gillis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 8:17am
yep
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 8:39am
DEVCON make a lot of it ! I know the steel epoxy will seal a gas tank that a hachet made an 'inspection slot' in it.......
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 10:32am
Thank you Jay. Clap I knew there was another brand my local engine machinist guy had me looking all over for 25 years ago. His way or the highway,cause he can work wonders if he wants to help you. Wink But don't ever expect much if don't follow his advice all the way.
Don't know if it was worth the effort as it was only a JD put put.LOLLOLLOL If Oh Shameless ever comes and visits I can fill him up on Black Label and let him express his anger on the popping johnny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 12:10pm
I watched Dobie Gillis when I as a kid.
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 12:42pm
I have used Lab Metal, however it must be very clean, they also make a high heat version and I used it to repair an exhaust manifold two years ago and it's still holding
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 12:49pm
I use the permatex/loctite epoxy mixer cups regularly. They come 10 in a can, and are part number 21425. Once in a while I get an old batch, one part or the other is dried out. I've been using this stuff on Roosa pilot tubes for years. It used to be marketed by Caterpillar as well, which is how I learned of it. Cures much faster than traditional JB Weld, and JB Quik wasn't good enough for pilot tubes.
This page was generated in 0.242 seconds.
