How to treat a tree stump,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: How to treat a tree stump,,,,
    Posted: 30 Jan 2020 at 12:56pm
 I finally decided to cut the dang Mulberry tree  that lines the walkway in back yard,,cause I cannjot stand to sweep up NO MORE friggin mulberrys...!! What I don't pick up gets on your shoes and ,,,,and,,,right straight on the tan carpet and that stain is he** to get out. It has a 14" trunk and I cut it down to about waist high as I wanna bolt the Anvil I fashioned out of a piece of RR rail and don't want any shoots coming out no more.
 What will be something I can pour on the stump to kill any of that coming up,,,??
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 1:20pm
It's been said to get a copper nail and drive it in the tree and it will die, that's how those trees mysteriously die on the Corp of Engineer's property that are blocking the second tier views of the Corp lakes around here..................
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 2:12pm
I bored a couple holes in the stump and poured Roundup brush killer in the holes. Did the trick here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 2:31pm
bore several large,deep holes or cut a 'crater' in the stump, pour some diesel fuel in it, let sit over night, next day, use propane torch to get her lit, then walk away. Stump will burn itself !
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 2:49pm
That's what I would do or some toridon
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 2:54pm
And bolt the anvil to a pile of ashes?
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 3:10pm
We use Tordon(sp) . Just apply it per instructions. It works great, been using it for several years.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 3:47pm
tordon will work.
However if you got roundup sitting around instead, I just brush the straight stuff on the stump immediately after cutting and it is over.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 4:12pm
Yep roundup is cheap can dump a whole gallon on it for about $10 Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 5:21pm
Git your lightest chain saw and 'gird' the tree.  Cut all the way around it at the bottom and then up 2 or 3".  That'll kill it.  It might want to start sprouting from one of the roots, but just keep mowing over it.  They don't want to give up.....
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 6:04pm
I only cut around a tree once that was bothering me.  It killed it or at least it doesn't sprout branches any longer.
TDF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDF Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 7:03pm
Tordon it. Follow the directions. I've yet to have anything survive it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 7:05pm
Mulberrys love to re-sprout...  The most important thing is to have e fresh cut, on the stump, so you can see some fresh milky sap, oozing up.  Then treat with at least 20% active ingredient Glyphosphate(roundup), just pour around the outer sap ring, till its wet.  You can use tordon, or almost any broadleaf herbicide(undiluted), too, but remember that these can also transfer, through the roots, to the soil, and kill other broadleaf shrubs, nearby.    If you have desirable shrubs, nearby, I'd go with the roundup, it does not transfer like the other stuff...Wink
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 8:08pm
Mulberry trees are one step above a noxious weed, I going to try the Roundup thing on mine.  I have barked mulberry trees all the way around as much as 4 to 6 inches and the leaves didn't even curl.  I cut one off, small like 3" diameter, painted the stump with acetone, I think the shoots waited until I walked back to the house then popped up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 10:29pm
That right there is funny,,JW,,,,Clap
   Ya know I actually like Mulberrys especially the black ones, and many years ago I bought these two trees for a nurserey that were susspossed to be "Fruitless Mulberry",,,and they were for bout 3-4 years then they both started puttin out the fruit and this Black one is right along the walkway to the east yard so it is a PAIN to keep from trackin them in the house. The other tree is the white berries and that tree is kinda out of the traffic area but I sure wish they had switched way back then cause the white berries are not as sweet as the black ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 5:18am
With whatever you have for a large bit, drill 4-5 holes around the outside in a downward angle, pour straight Remedy in the holes drilled about 3" deep.
In your dry climate, may get 2-3 years use of the vice or anvil mounted before it starts to come apart.
Another option is to drill holes slightly smaller than a lightning rod OD. Cut the rod into 3 or 4 6" lengths and drive them into the drilled holes.
Rods are clad but enough copper to kill most any tree, just cut very hard and you can take the teeth off a hack saw in a couple minutes.
I used a Dremel Tool to cut a bunch of lengths and the 4"-6" stumps I used them on could be pushed over with your foot within 12-18 months.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 5:58am
re: Yep roundup is cheap can dump a whole gallon on it for about $10
sigh, up here, it's getting close to 100 Canucks
that's why I use vinegar/salt/soap
cause I'm not a rich farmer Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 7:02am
Actually, around here, a big mulberry stump can last for years.  We used mulberry for fence posts, as termites didn't seem to like them.  Don't know if this holds true, in the desert, though...Wink
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 8:39am
I've had good luck with Ferti lome stump killer . Just brush it on a fresh cut stump . About $12 a pint I think .
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 9:28am
Have your friend from NE to hike his leg on it a time or two.
The only down sided will be that the people from the petrify forest will be after you for stealing one of their tree stumps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 9:46am
 Hey Jay,,,,what are the amounts of thet concocktion you talkin bout cause I gots those ingredients settin under the sink,,,, just sittin there doin nuttinClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 9:48am
 Yeah Cabin,,,but,,,but,,I ain't wantin him to do any harm,,,like suffocate them 7 kitties that stay in the garage,,,,LOLLOL cause it right next to the tree,,,,,,,LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 10:11am
1 jug ( US gallon) of vinegar
1 cup of salt
3-4 srirts of liquid dish soap
I find it best to pour vinegar into open pail, add salt, stir well until dissolved, then add soap, stir to mix in soap. You can poru back into original vinegar jug..just be SURE to remove label and mark it 'KILL ALL'.
best to apply 10-12AM, after morning dew is gone but before 'heat of the day'. Usually stuff dies by 3-4PM that day !
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 12:29pm
Holy shi$  I think you better come south of the boarder  with a red tank labeled diesel fuel and fill it up with roundup before you go home.  Never want to run out of fuel.Wink
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2020 at 1:39pm
Tordon is the best but straight Roundup will do it. Might have to do a couple treatments with Roundup.
Tordon is a one time deal----That's great stuff!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2020 at 11:08am
Mulberry trees are still dormant, do I need to wait until they bud or can I go for it now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2020 at 5:38pm
Does your lawn need cutting?  Generally speaking, if the grass needs cutting, then sap is runnin, and you can make a fresh cut, about 2" lower than the old cut, to apply the RU in.  Cut don't have to be all the way across the stump, just through the bark...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2020 at 11:06pm
I used to carry a bow saw with me when planting along a fence line or next to a creek, i'd cut off branches overhanging the field while standing up on the tractor, then squirt the cut part with tordon. had it in a spray bottle. by the time of mid summer the whole tree was dead just from that cut branch. mulberry is good firewood, and Joe...if the tree you cut down has a log as long as the width of your lambo...you can mill you out a colorful rear bumper for it! after you kill your stump, and the top is dry, spray some water sealer on the top, that should keep it from rotting away for a couple years. may hafta do repeat treatments each year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 3:47am
  Well,,I'll tell ya'll something,,,These weeds just DO NOT know how to read or understand that the weed killer I mixed up from ya'lls instructions is suppossed to kill em dead,,,Chit,,if anything they is growin faster than before,,,,!!! I finally dumped out what I had left in the quart bottle right on some and bout all I got was a few white spots on the leaves,,,,,,,Guess  I'ma check TSC and see if they gots the Tordon...I ain't been in there since Ms. Big Ones gots transferred out to a store in Nebraska,,,,,,,,,sniff, sniff,,,,,
 Say,,I just remembered something,,,last time I was in there,,(I meant IN the store!!) I picked up a bottle of Cinnamon Sugar by Baker's Select that sure was good with my mornin coffee,,!!  I called to see if they still had some and they tell me they no longer carry it. Was a promo during Thanksgiving. Has anybody seen some in their TSC store??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 5:31am
The last 2 mulberrys I had ( mother, daughter) I did the diesel, burn method. Took days as it slowly smoldery-burned it all. I drilled lots of 1" holes, 1 foot deep with a spade bit,filled with diesel, came back next morning and lit it up. Need big holes to let air in,smoke out...
I woodn't use a stump in the ground for an anvil base BTW. Stump is still kinda living or rotting in the soil...NOT a stable platform....cept for a maybe flower pot.
