Forklift ID
BigAl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigAl Quote  Post ReplyReply Direct Link To This Post Topic: Forklift ID
    Posted: 29 Jan 2020 at 11:54pm
Have an AC forklift. Where should the model number be if it's not on the dash? All I know is it has a 6 cylinder engine, runs on propane. Hasn't run in 20 years. One thing that might be a clue both sides are lead weights. I'm just trying to figure out where to start. Decided to pull the plugs and squirt oil in the cylinders before I try to bump the starter. Can't get to the crankshaft. One end has a hydraulic pump the other the transmission.
Need to find a place to post pictures so you can see it.
Looked around on the web, it looks something like a FL-60-24 or that's as close to it as I can find.
Al in Tucson
