175 and 17 Hitch
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: 175 and 17 Hitch
    Posted: 27 Jan 2020 at 1:19pm
Can a 175 3pt hitch be put on a D17 SeriesIV w/Snap Coupler?
Thanks
Tom
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 3:11pm
YES! I have sold several 3pt hitches off a 175 and 180 tractors that were used to convert a D17 IV to 3pt.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 4:35pm
Thanks Alex!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 11:52pm
I did mine 3 years ago. I had a heck of a time getting 1 lift arm off and had to buy a short 1" air gun to get the bottom bolts out of the tractor. I loved it after it was done. I had an add on 3 point on it when I bought it. The AC unit is far better than any add on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2020 at 7:47am
Thanks guys.  Looking at a salvage 175 this weekend hopefully...happens to have the 400 loader on it that I need for my D17.  Also want to get a series IV D17 down the line, might be cheaper to get a SC version and swap out the hitch with the 175.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2020 at 7:48am
If this works out all I will need is a crankshaft hydro pump for the D17.  Anyone got one or do I have top make one? (Lord help us all if I have to do that)
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 6:58am
Get pump drive 1101-0404 off of eBay.  That bolts to your crank pulley.  Buy the shaft that goes with it.  I don't have a number for that as I had the shaft.  The pump I have is an Eaton 26013-LZC F140530FM.  I got it from Hyd Surplus.  Then all you need is the bracket to mount the pump.  It looks like this.  Good shop can make one if you give them the pump and the distance between the mounting bolts.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 7:55am
Hi Aaron,
Good stuff.  I found the crank mount you mentioned, but no dice on that shaft#..Anyone have a number?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 8:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 8:47am
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 9:12am
Countryside Tractor Has The Parts 717-921-0421 For The Pump Drive
Edited by Alvin M - 29 Jan 2020 at 9:32am
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 6:16pm
For the hub
for the shaft
These are Ford parts but will work on a D17
Factory setup used a chain coupling with a 10 tooth sprocket. I modified a standard #50 sprocket and shortened the chain. I got these from www.surpluscenter.com
I am working on making the plate and spacers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 5:47am
Thanks Joe!
This page was generated in 0.281 seconds.
