WD45 Governor Assembly |
Post Reply |
SmithCreek
Bronze Level Joined: 04 Jan 2010 Points: 8 |
Posted: 18 Aug 2010 at 11:40am |
Where could I find a governor assembly (with or without distributor) for a WD45 like the one pictured below? The threaded portion (for the rear distributor bolt) split off mine the other night when I was tightnening back up after adjusting timing... Thanks
Edited by SmithCreek - 18 Aug 2010 at 11:42am |
SmithCreek
Goose...
This is not a picture of my tractor, I posted it to show the part I'm looking for. Sorry for the confusion.
Also the bolt didn't shear off, instead the treaded portion of the cast iron housing itself broke off leaving me with the bolt and a piece of the housing in my hand...not good.
CJohnS MI
Orange Level Joined: 27 Jun 2010 Location: Lapeer MI Points: 326 |
You sire, are the very sort of person JB Weld was invented for. If the piece in the photo truly is like yours - the part that attaches to the engine/timing case is held on by three bolts and it is aluminum. The inside one gets overlooked by a lot of people - until just too late. Anyways, well scrubbed surfaces, JB Weld and a fresh gasket - and 20-30 years from now, it will still be holding. Slipping on a fresh gasket between repaired joint & engine means it won't stick when you disassemble at some later time. |
Ray
Orange Level Joined: 21 Sep 2009 Points: 1979 |
I would have the coplete governor assembly for $275.00.Would have the body (part you broke) for $80.00. 785-353-2392 Thanks
d17brown
Orange Level Joined: 11 Sep 2009 Location: farley iowa Points: 1698 |
i have one for 200$ complete
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20971 |
One bolt/clamp is enough...been there.
Post Reply | |
