frozen oil????
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: frozen oil????
    Posted: 23 Jan 2020 at 3:09am
went to use my canola oil the other night on the grill, and it was frozen solid! Darrel...you mixing water in them canola seeds up there? PffffT!
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 6:26am
Being from Nebraska Shameless cold weather should have given you the knowledge to bring your Canola oil inside! I can't poke you too bad as yesterday I had a Hay Customer show up who had contacted me ahead of time and I had forgot to plug the loader in! Took a battery charger and a lot of glow plugging but I got it started! As I get older I would forget my ass if it wasn't attached!
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 7:50am
lol, coconut oil same deal... temps at or above 76*F liquid, below that solid, at some point ROCK solid.
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 2:09pm
shameless outdoor kitchen shut down weather too cold, come back in the spring
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 4:59pm
Hmm - someone gave me 4 cans of Target brand - ATF fluid said Dextron type.
Broke a hydraulic line on snow plow and figured I would top off pump on truck with that oil - was below ZERO out and so was oil - went to pour it into hyd pump reservoir - was like putty and when pouring it was a long sagging string of red goo.
 so had to find other ATF and give that junk away
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2020 at 10:20pm
cooked out in the shack all day today, the canola oil was all thawed out this morning and didn't look any dif than usual, used some of it today.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 3:49pm
Coke my skid loader used dexron for hyd oil. It leaks on my cement. It has never been stringy.   And it's cheap dexron too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2020 at 10:26pm
my Gleaner combine used dextron for hyd fluid, never any leaks, never stringy, lots of snow blades use dextron, sounds like someone used some empty containers and put something else in them.
This page was generated in 0.338 seconds.
