What Oil & How Much On a WD |
Post Reply ![]() |
hardwood61 ![]() Bronze Level ![]() Joined: 16 Aug 2010 Location: MN Points: 29 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Aug 2010 at 8:47am |
Anybody know what type of oil to use in a WD's transmission and differential? Leaving for hunting land on Friday and wanted to put in fresh oil - just bought the tractor and waiting on manual I ordered. I appreciate any help.
Larry |
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
I believe it hold 17 quarts, I use 80/90 gear lube. there are 3 separate comparments. Drain plugs are located on bottom of transmission, bottom of differential, and bottom of hand clutch housing. Fill all 3 compartments through transmission filler plugs (2)
Matt |
Thanks Matt, are you saying you drain 3 plugs but you only fill using 2?
Yes, there are 3 lower "sumps" for the compartments that need to be drained. the cases are "open" on the inside so they will fill through the transmission filler holes
OK!
Thanks! |
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
The 2 rear most plugs on left check same levels but for filling you need both or take forever.
So then ... do I use 80/90 gear lube for the hydraulics and transmission and differential? Seems odd to use for hydraulics - with the possible contamination.
After re-reading the responses I think I get it now ... Gear lube for the clutch, transmission and differential, but the hydraulics is a separate compartment with its own drain plug and fill at dip stick ... is that it? Just trying to make sure I don't screw it up ... hurry up USPS with my manual! Edited by hardwood61 - 18 Aug 2010 at 9:08pm |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2244 |
The transmission, differential and hand clutch fill plugs have square heads; different sizes.
The filler with the "bayonet" dipstick is for the hydraulics. Holds 6 qts. Originally called for 20 Wt non-detergent oil but most use universal hydraulic fluid nowadays. In addition to the "magnetized drain plug on the bottom of the housing, there is a small drain plug
on the hydraulic control housing near the pump on the RH side which should also be drained.
caRon ![]() Silver Level ![]() Joined: 14 Sep 2009 Location: Indiana Points: 298 |
I use JD hi-guard universal trans/hydraulic fluid. Works really well. |
CA Tractor
Post Reply ![]() |
