Off Color TD 14A
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Topic: Off Color TD 14A
    Posted: 13 Jan 2020 at 8:27pm
    I am looking at a International TD 14A because I cannot find a AC close here.   Has anyone on here owned or used one. How are they? Just needing to clean up some land. How hard is it to free up a cutting clutch? Thanks for any info.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 8:41pm
a cutting clutch?
 They are tuff old beasts, just prone to cracking heads when shut off hot or been worked hard on lean fuel.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 8:55pm
You referring to a steering clutch?
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 11:15pm
Is it all there and operable?
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 6:34am
acjwb,
If you have a chance to post on the Red Power forum under construction equipment they can answer your questions too. Yes if its steering clutches, it could be a issue. I am not familiar with that model.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 6:53pm
Our county road department had 1. I was interested in buying it but The boys said the rear end was always out of it.
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 7:53pm
I grew up on Internationals, that is why I have Allis Chalmers. I always referred to them as 13 letter SOBs. The TD 14 steering clutch extraction requires removing everything on the deck to the master clutch including the transmission cover, you will find tapered bolts that fit in tapered holes for the deck alignment, if it is a 141 series that has power steering, you are in for a treat. Be careful to mark the brake drum to the driven flange because the bolt holes are clocked and will only go one way, if you don't swear now you will about the time you have to put the brake bands back in, should you buy the tractor PM me and I will help all I can, there are a few tricks. Tad
