wtb 12,14,16hp kholer engine
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: wtb 12,14,16hp kholer engine
    Posted: 17 Aug 2010 at 5:59pm
looking to buy a 12,14,16hp kholer engine that will fit in a 912 allis chalmers lawn mower perefer centeral iowa thanks call anytime 641-373-0467  Nick
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 6:09pm
Ditto - only here in lapeer/mid-michigan.
(thought I'd hijack yer post)
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 6:48pm
HELLO
 I AM A KOHLER ENGINE DEALER AND THE K SERIES IS NO LONGER AVAILABLE AND IF THERE ANY SHORT BLOCKS LEFT THEY ARE VERY LIMITED
tractorkid1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorkid1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 7:28pm
Northern Hydrualic list magnun singles in there current book.A single cylinder magnum will work as long as the shaft size and length are the same. Then again I don't think that a 912 uses an electric clutch on the front like some other garden tractors (Deere, Cub,  Bolens etc). The only thing to make sure it would work is to see if drive shaft would mount up to the flywheel. A kill switch would be needed to turn it off, like a B&S engine wired to ground.  Ron
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 9:20pm
There's an ad in the classifieds on Simpletractors.com selling lots of engines. You should be able to find what you need there. I Briggs will also fit in your tractor with a few light modes. Whatever you do I'd recomend going to a 16HP engine. In the long run for a little more cash you can upgrade to more power and you'll like the power in these tractors over the 12
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 1:51pm
Just came back from picking up an engine. Came with a Crapsman tractor attached.
