39 B
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Topic: 39 B
    Posted: 10 Jan 2020 at 12:00pm
I just picked up a 39 B and it has 6 bolt 15 inch rims on it and the bolts go all the way through and they have a  nut and lock washer on them.  They also put one castle nut on each rim.  Never seen this before.  I thought the 39 B's had the rim welded to the wheel center.  Anybody have any ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 12:31pm
Wyane,
 Congrats on the new "B" I would like to see pictures and I know Bill Long would like to see his favorite tractor too!
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 12:58pm
I think they where riveted on and I’ve seen where people grind the rivers off and put through bolts so they can take on and off like a new rim
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 1:22pm
I believe that type of hub was on the prototype B tractors under serial #101.  Who knows how much swapping of parts has gone on throughout the years.  When I worked a Ford dealer in high school we were always working on 928N tractors. Tractor jockeys would bolt things together in in matter they could to get a running tractor that an unknowing yuppie would buy.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 3:21pm
I've been told both rivet on rims and bolt on rims are correct for 39 that the switch was made some time during the year.    My 39 s/n 26240 had rivet on rims.   On a slightly different subject I have seen where the threads in the hub were stripped and some one used nuts on longer bolts on the back side of the hub to hold the rims on.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 7:22pm
I  have B 22xxx with riveted hub to wheel.
This page was generated in 0.168 seconds.
