trailer plug extension
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Topic: trailer plug extension
    Posted: 09 Jan 2020 at 5:28am
  I have a 4 prong flat plug in on my pickup for trailer lights. The have a spring loaded dust cover over the plug in that when there is a plug in it the spring on the cover is so strong it bends and clamps the wire against the plug so tight it won't be long and the wires will start breaking off. Is there an a longer plug made like an extension to get the wiring out past the cap? Or what do you do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 6:03am
I just use a 4pin to 7 pin adapter and use the 7pin receptacle these days... the original 4 pin setup rotted away after 20 years for some 'silly' reason....
I keep TWO adapters in the truck.......
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 6:29am
i did the same as Jay right up front.  Been that way for  bazillion years, well maybe only since 2012.  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 10:36pm
yeah I gots adapters too, just gotta remember to put them in whatever vehicle i'll be using at the time. one time I had to puts a toothpick shoved in one to hold it in contact, guess they wear out too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 10:41pm
Like Red Green says DUCK TAPE the handy mans weapon or fix for everything
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 11:16am
Modify the cap, or break it off! I don't use the four plug anymore, but have the 7 to 4 IF I ever need one. The last 4 I had, I cut the cap off then plugged in an old pigtail to keep dirt out.---wont do much for water.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 11:58am
I would search the net for what you are looking for.  You may also want to do a search for a 90 degree adapter.  That may solve your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 12:37pm
Gary,
I took my flip caps off. Maybe not the wisest thing to do? But I use both plugs for remote pumps. I cant have the caps and have both plugs in place.
Maybe apply some protective grease on the contacts if you remove the cap?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 12:53pm
yes, LOTS of 'electrical' grease...clean them real good first though.... any 'salty water' residue will allow electrons to flow, usually the 'brown' wire connection( next to 'white') will corrode first, probably cause tailights/running lights are on more than brake/turns are....
you can also toss in a 'plug tester' to 'fill the void', again well greased....
This page was generated in 0.146 seconds.
