Time for more new tools |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1569 |
Topic: Time for more new toolsPosted: 08 Jan 2020 at 7:51pm |
So I love buying tools. If it works as advertised and I can see a use for it I'll buy it.
Any way today I had a warranty job come in. I put an alternator in a Honda van about 8 months ago. Well today it come in with the alternator bracket broken and the bottom bolt broke in the engine casting. Very little room to work. I ended up using a Dremel and cutting a slot on the bolt. Then with a bunch of luck I used a screw driver bit and a 1/4 inch wrench to get it out. But I got to thinking what if I needed to drill this out. I said to my my self it's time for more tools. So here is my list. A right angle drill. Probably air operated. And some stubby drill bits. What are your guys thoughts on either of these. Any good, bad, brands to avoid, etc. I like stuff with warranty. I'm not opposed to spending money if the tool is good quality |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55283 |
Posted: 08 Jan 2020 at 8:57pm |
If I remember right snap on had one, that was air operated, right angle, with bits that screwed into the end of it. Pretty pricey, but worth the $, for the right bolt/situation. I'll see if I can find it.
Can't find it on line, right now, But go to snap on, and search short left hand drill bit set. That and a die grinder would get you a long way toward what you want...
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34627 |
Posted: 08 Jan 2020 at 11:29pm |
Yup, left hand drill bits worth the money in the right places.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
shameless dude
Posted: 09 Jan 2020 at 2:11am |
I love buying tools, gadgets, lights, and other things too!
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5181 |
Posted: 09 Jan 2020 at 6:19am |
Slightly off topic, when I first started in the machinist trade I worked with an old man who had been in the business for about 50 years. He used to love to correct me whenever he could and the way he did it was usually pretty funny. One day I said something about a drill bit and he said, very sarcastically, "it's not called the Acme Cleveland twist drill BIT company. They're called drills". Then everytime he needed a drill he'd say something about needing a bit and he look at me sideways and I would repeat his lecture back to him. He'd cackle a little and say something along the lines of "well I was wrong, the youthful mind of America is capable of advanced knowledge". I sure do miss that old man
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 09 Jan 2020 at 6:31am |
OK, I'm trying to figure out why this is a warranty job......sorry I digress.. I would NOT buy an air powered RA drill, 'useless as teets on a bull' for THIS job ! The air hose WILL get in the way, wrap around some $$$$$$$$ thing and oopsy... Buy a BATTERY powered RA drill...NO air hose or power cord. Up here 'short' drill bits are called 'jobbers', BTW.
bobkyllo
Posted: 09 Jan 2020 at 7:33am |
The customer thought it was a warranty job because as far as his dadh was telling him the alternator was not working anymore and I had just installed a new one.
Once we got into the job I had to call the customer to see what they wanted to do. Of course they wanted it fixed but I wanted them to see what was wrong before I went ahead and tore it apart much farther |
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1361 |
Posted: 09 Jan 2020 at 9:02am |
Look on McMaster Carr.com for high speed steel short length drill bits. That's all I buy for common drilling at the plant. If I need a longer bit I only order one. The black oxide 135° point angle ones are cheap and great quality compared to any store bought bit. My personal ra drill is a souix? Electric, millwaukee is the same. Works for me, good luck
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 09 Jan 2020 at 9:34am |
Boy,,you gots you a tough one there,,,,,, The way I read it,,,,the bracket "Might" of broke ,for many reasons not even related to anything you did,,,OR the bolt broke for same reasons and most likely not because of anything you did. First thing I would do is show the owner the broken stuff ,,then repair the bracket and replace the bolt. THEN reinstall the alternator and check it with a volt meter. If alternator is putting at least 13 volts then THEY owe YOU for the labor for repairs to the bracket and bolt,,PLUS the R&R of the alternator. Fair is fair for both parties. On the warrenty for the alternator, I always buy at Autozone as they have an "UNshakable Warrenty of 1 year for the Cheaper parts or Limited Lifetime for the item that is just a few bucks more. I always let the customer make that decision. Good Luck,,,,
bobkyllo
Posted: 09 Jan 2020 at 2:22pm |
Once I determined there was more wrong then just the bracket I brought him in to see what's going on. He was the one who suggested the welding idea the second time I worked on this. He did say that he'll have to eat his words. He told me to weld that bracket and it should be fine.
So now that we have this in for the 3rd time he was very understanding. He said to charge him what I felt was fair. He said he trusted my judgment. I tested everything out after I put it back together and it all seems to be running well. I sure got lucky that bolt come out as easy as it did though |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 09 Jan 2020 at 8:00pm |
Sioux makes a nice 45 deg angle drill that is a compact unit , I have a couple air drills and find them useless as speed is not easily controlled and they eat drill bits .
A good electric variable speed drill is worth the money Edited by Coke-in-MN - 09 Jan 2020 at 8:03pm |
Dakota Dave
Posted: 09 Jan 2020 at 11:14pm |
For aircraft work we use right angle air powered drill motors with threaded drills. They can get in a very small area. Air drill have much greater power for their size than any other drill. The down side to theaded bits is the cost.
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 14 Jan 2020 at 1:15pm |
If you ever have to do exhaust manifolds on F series or GM LS engines, get the Promaxx kit. It has a jig that centers and makes you drill straight. It also has a 1/4" air ratchet that turns twice the speed of a normal one and a drill chuck with a 1/4" drive. It's half the size of any right angle drill you can buy. The day I bought mine I knew there was a V10 coming in for manifolds. All but 2 studs broke off so the Promaxx kit paid for itself on the first use.
They make drilling jigs for just about everything that's known for breaking bolts or studs. Absolutely falls under FRUSTRATION ELIMINATION...
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 16 Jan 2020 at 9:42pm |
Brian, do they make one (Promaxx kit or the jigs) for the 40 to 60s Allis Chalmers tractors? I need one for the WD45 right now.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 17 Jan 2020 at 6:26am |
Walter, I mean Ted This would help for a whole lot less, or give you an idea of going about it. |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 17 Jan 2020 at 8:18am |
Mine came off the MAC tools truck on special. Came with the stubby bits and a nice case for all of it. Good drill at a good price
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
