Filters Question
LOTM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LOTM Quote  Post ReplyReply Direct Link To This Post Topic: Filters Question
    Posted: 08 Jan 2020 at 5:37pm
Hello, I recently acquired an Allis 185 with a bucket attachment. I am wondering if anyone in here can help me find the part numbers for the filters? If I am correct there's oil, transmission/hydraulics, fuel, and air filter. I would like to get these changed and help my tractor last as long as it can.
What type of oil should I use as well? I live up in Wisconsin so it does get cold in the winter when I'll be using the tractor to plow.
Any other maintenance help would be appreciated as well, like where are all the grease points.
Any help, or even a point in the right research direction is greatly appreciated.
Thanks.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 6:32pm
Your local Agco/Masssey dealer will sell you the correct filters and oil.
After you have the part(s) numbers you can go to your local auto parts for the engine oil filter cross reference or maybe Walmart for oil.
It just depends how deep are your pockets?
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 6:56pm
Engine oil filter is AGCO # 74027979, fuel filter is AGCO # 74028945, Hydraulic oil filter is AGCO # 70239930 for the short one and 70253952 for the tall filter. I sell the tall hydraulic filter for the 180-185 tractors where i work. Air filter is AGCO # 70243163.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 8:43pm
Get an operator's manual for your tractor.  They can be found cheap on e-bay.  It will tell you everything you need to know about the tractor, including lubrication spots and the types of fluids and their capacities.
Edited by DSeries4 - 08 Jan 2020 at 8:44pm
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 9:36pm
Welcome to the forum. Google AGCO parts books. View as a guest. This will be a good tool for any repairs you may need. They also have the BEST operators and service manuals.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 9:51pm
A good 15WX40 diesel engine oil will work. A 10WX30 diesel engine oil will work well for you in the winter. I ran 15WX40 in all my AC'S since 1976. I do run it year around, but I am usually able to pick my winter days when I use the tractors. I put out enough hay on warm days to last for several weeks at a time, usually can find another warm day in that time to put out more hay. You will be wanting to use straight #1 diesel fuel in Dec, January, and Febuary, maybe thru March if it stays down in the zero degree temp range.
Edited by HD6GTOM - 08 Jan 2020 at 9:54pm
LOTM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LOTM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 11:05pm
Awesome! Thank you all for the suggestions and help!
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 11:10pm
WELCOME TO THE FORUM, the best place on the net to talk A-C tractors! Nice to see another member from WI join! I see REEDE beat me to the numbers, but if you are within driving distance of NE Wisconsin near Shawano, I have all those filters on the shelf under the Baldwin brand of filter except the air filter, here at my Allis-Chalmers tractor repair shop. If you have any other questions about your 185, this forum is the place to ask- lots of knowledgeable guys here.
www.awtractor.com
A&W TRACTOR 920-598-1287
LOTM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LOTM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 11:22pm
I live in Pulaski, so very close to you. Where is your shop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 11:39am
Between Cecil and Gillett off HWY 22, i'll send you a Personal Message
www.awtractor.com
