TSC LARIN drill press vice
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: TSC LARIN drill press vice
    Posted: 08 Jan 2020 at 2:34pm
Anyone know if these are any better than whatever harbor freight ? Thanks
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 3:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 6:10pm
Thanks Gary .
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 2:18am
I have one from HF, has worked for me for prolly 10 years. it's not has heavy in weight as others, but has done the job o-k.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 5:28am
Thanks Dale .
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 6:33am
I got the HF one.  The quality leaves something to be desired, however I am a casual user and it serves its purpose for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 6:41am
I've got 3 or 4 of the them ( have 2 drill presses), NONE are beside the drillpress I use, hmmmmmmm)
The big deal is to put thread locker on the screws securing the movable jaw ! Tighten just enough for a smoooooooth fit. From the factory, they're too loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 6:57am
Yeah I don't need one very often so a cheap one should do . Gotta be better than nothing . Thanks
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 8:56am
Spend the other 11 bucks on there cheap drill bits. Wink
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 9:15am
  Yeah,,AC,,you answered the main point,,,,Wink It all depends on how often a guy uses the tool,,,,AND,,,how close you want your work to be. I've got 2 HF ones and have always been satisfied with their performance,,,,,Clap
  Say,,,maybe the Guru's here can help me ID an older vise I picked up at a yard sale ,,,It is 6# wide and 12" long with a removable handle. Only'ist numbers on it are " #3 " The end of the screw is square where the handle goes. The moving jaw has adjustable plates underneath for really close work.  That sob weighs at least 50#,,,,,?? Anybody recognize it,,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 1:11pm
Sure could've used one when I drilled a 1/8" hole in the D 15 top link adj rod to put in a roll pin . Now when I need it I can find it . Need to just get a cheap one so I'll be ready next time . Thanks guys
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 6:28pm
I have found that there is more wobble in my cheap drill press spindle than in jaws of my cheap vice.  I do have a very good drill press with a very good vice for the stuff that requires it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 7:39pm
I would think the quality of the HF vise is as good or better that the one from TSC. IMHO the prices at TSC seem to exceed the quality of their products, especially their tools.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 7:54pm
Probably madein same facory by same chines machinest .
Have a couple cheap ones by drill press but when it's got to be right - use the vertical mill and Bridgeport vice clamped to the ways on the mill
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 8:21pm
YEP... Hong Jong FU makes TCS on M-T-W... then HF vises on TH-F-S !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 5:43am
Yeah those vices look pretty similar to me . Thanks
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2020 at 11:44am
I have a cross slide and a regular one from HF, and yes they are loose but do hold really good. I have drilled some nasty stuff that was being held in them. Also use them as a welding vise since welder is close by. I think they are worth the price. IF ya gotta have +- .0001 --- No good, but for our use they suffice !
Post Options Post Options   Thanks (1) Thanks(1)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2020 at 12:05pm
Thanks Sonny . Kinda what I'm thinking .
