allis chalmers c with cab
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers c with cab
    Posted: 08 Jan 2020 at 11:06am
I thought this was funny.
hopefully someone can post the picture.
Edited by Acdiesel - 08 Jan 2020 at 11:06am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
AC7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7040 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 11:17am
1953-WD45, 1949-G, 1950s Snap-Coupler All-Crop Drill, 1956 Roto-Baler, 1945 All Crop 60, Snap Coupler Subsoiler, Plow, Gleaner F, 505 wagon
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 11:25am
How ya gonna see out them winders? Confused
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 12:44pm
Maybe similar to a NASCAR windshield tear-off, for when you want to see out front . . . .
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 12:50pm
If you are going to build a cab, why not make it two stories...?
The big question is how much higher does it go?  Couldn't fit it all in frame!
Last one, I want to see what the fella looks like that can drive this rig!  LOL
Great stuff!  Thank you for posting!
Leave things better than you found them.
1941 Model C (restored 2020)
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 1:54pm
Inside of cab...
Parts tractor or repair .will need rings & carburetor I believe the rest of it is there . It has a home made cab on it that we can remove if not wanted.
 So wheres the mag and the starter and generator?  Confused LOL
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 2:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 2:03pm
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 2:07pm
Why is the engine bright orange if it needs all that ?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 2:24pm
The ad says it has automatic transmission!  Wow, a c powershift!!!
JC, the starter, mag, and generator are probably in the attic.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 2:36pm
You can buy a tractor and an outhouse at the same time.  Wow!
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 3:54pm
By the red color of the cab is that considered a REDNECK cab. Leon
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 6:27pm
What if the cab did double duty, and was also used as a tree stand for deer hunting.  lol
 Tim
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 7:14pm
It even comes with one of dem Cell phones that use a tin can and string.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 10:23pm
Deer stan. Thas whut I's thinkin and you cud drag yore kill hom wit it.  LOL       Leon
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 7:59am
No oil filter and base either
Wink
I am a Russian Bot
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 9:12am
I guess "the rest of it" means different things to different folks! LOL
WC, CA, D14, WD45
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 9:43am
So what was the true purpose??? Wonder if they used this in a stationery position using just the PTO/ belt pulley (although not one in pic).  Has me curious as to why someone would build something with windows so high (though it looks like a board can be removed that would enable the driver to see) and the contraption so big.  Maybe just bad designer and carpentry...….
D17 Series 1
Allis B- 1939
Allis B- 1945
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 9:59am
I don't think it was ever used for anything!  The 'cab' is just setting on there and held on with ratchet straps. The tractor was obviously never running recently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 10:02am
 Zactly what I was thinkin!
This page was generated in 0.123 seconds.
