Allis ib rear rims
Stookless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Topic: Allis ib rear rims
    Posted: 08 Jan 2020 at 8:20am
Does anyone know the correct rim type for the rear of a IB? Mine has the 4 bolt on one side and the continuous bump on the other. Then there is the 4 bump rim. Which would be factory original?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 8:29am
If I remember correctly, my IB had the four rim bolt clamps like my B had. Nothin' trick about it. Coarse, over the years, things get changed around, so one of your wheels may have been a replacement to the original if one of the wheels was rusted out or damaged....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 8:38am
Yes it does have the four bolt eccentric on one side like a normal b, but the rim is the different part being that the bump goes all the way around instead of 4 seperate bumps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 8:44am
what year ?  ALLIS changed over the life of the B and C... the IB was not special, just depends on the year.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 8:48am
My IB has the same rims (4 bump) as my B's.
Does anyone have an extra set of decent IB fenders to sell ?????
Edited by WF owner - 08 Jan 2020 at 8:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stookless Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 10:40am
It is IB #3506. Not sure of the year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 11:02am
According to TractorData.com, 1953 was the last year of IB production and 1953 started with IB2570. They also say there were 2850 built. As with many models, serial numbers started with 1001. I'm quite sure (and someone can correct me if I'm wrong) that pre-1946 models used model B serial numbers.
Production of the IB in the 50's were usually under 400 per year, so I find it hard to believe they built over 700 in the last year of production. (Maybe???)
Here's the link to Tractor Data:
Edited by WF owner - 08 Jan 2020 at 11:04am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 12:20pm
Maybe it was built when they changed from one style rim to other.
