WC front axle oil leak
Rick(NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick(NC) Quote  Post ReplyReply Direct Link To This Post Topic: WC front axle oil leak
    Posted: 05 Jan 2020 at 4:11pm
The narrow front axle has a steady leak from the bottom. Is the 70212916 (lower seal, seal retainer, upper seal and the washer) assembly still available? Or is the 70202101 lower cork seal all I need? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 8:00pm
I went thru the front end of my narrow front CA with some new bearings and the bottom seal. Within a month, I had gear oil leaking down on the front axle. Since everything worked great, and I could steer with one finger while running the Woods belly mower, I just put grease in it. Corn head grease might be best, but I didn't have any at the time.
