Grab Handle |
tedholman
Topic: Grab HandlePosted: 02 Jan 2020 at 6:36pm |
Is there any place to get a replacement door grab handle for a 8000 series cab door?
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2484 |
Posted: 03 Jan 2020 at 8:35am |
Is it broken or just worn? If the padding comes off,they are pretty sharp. I have taken a couple of those off that had bad padding and then buffed off the rest of the padding. Then you can slide a piece of 5/8 heater hose over the strap. You will need to lube the hose to get it over the strap with something, it's a tight fit. I just rivet it back in place and it looks pretty good and is a lot easier on the hands. You could also take the one off of the right door and put it on the left. The right door rarely gets used here.
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1361 |
Posted: 03 Jan 2020 at 11:45am |
I ordered one from agco a few years back and it was a piece of bent tubing. I never used it . I been thinking about making mine like Lynn said but have one of the leather belt guys sew two pcs together and slide that over a new SS strap. Could even have it stamped with the AC logo.
Unit3
Posted: 04 Jan 2020 at 9:02pm |
It would look like a farm boy fixed it, but how about a length of serpentine belt? It would be black and hold its shape.?.?.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: 04 Jan 2020 at 11:19pm |
Looks alot like my 88 LaSabre pull strap...but I bet it is NLA too
