AC 170-175-180-185 |
Post Reply |
WNYBill
Silver Level Joined: 04 Jun 2016 Location: WNY Points: 276 |
Posted: 01 Jan 2020 at 11:03am |
Do I have this right? The 175 in just a newer version of the 170 and the 185 is just a newer version of the 180. What are the real life differences and which is a better tractor?
Bill
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3285 |
you can search the archives here, but engine rpm, trans and torque housing gears, final drives have some different parts, 236 vs 248 perkins engines are some differences. The tractors are 90% the same. 170 and 175 and 180 185 built in overlapping years.
Visit www.agcopartsbooks.com and start comparing.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4862 |
Yes, the "5" tractors were simply sped up versions of the "0" tractors. For instance, the rated load rpm of a 180 is 2000, and 64 pto hp, the 185 is rated at 2200 and develops 74 pto hp, while fuel setting is only slightly higher. The marketing strategy was to pull the same smaller equipment faster than the previous tractor you used, thus saving drivetrains. As speed increases, the torque falls, torque is what does the work, but also damage. By the time these tractors came out, a 75hp tractor was no longer the big horse anymore either, in many cases.
tbran
hey Ed, what is difference in timing advance ability between the pumps with and without the trimmer screw in the bottom.
injpumpEd
Without digging spec sheets out, ones without advance are the same whether 180 or 185, the ones with advance are same as each other as well going odd memory. It seems they have 5* pump advance.
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20191 |
I seem to remember 24 degrees BTDC on the old non-advance engines and 18 degrees BTDC on the later models ??
injpumpEd
26* on non advance, 180 w/advance is 22*, 185 with advance is 24* according to a sheet I have for all sorts of AC applications. They would probably start better at 18* lol! The 200 tractor underwent many changes, first pumps were 5* and timed at 24*, then went to 8* pump advance to time engine to 18* for better starting.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11746 |
From a wiring point of view, there are some minor differences at the dash and going out to the engines looking at a couple OEM harnesses that I have here. Not sure on the rear lighting harnesses. Never could get a rear harness that wasn't cobbled up! LOL! Steve@B&B
Post Reply | |
