A crazy idea that needs others' input
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: A crazy idea that needs others' input
    Posted: 29 Dec 2019 at 9:34pm
Okay guys, I got one crazy-A$$ idea to bounce off'ya.
Just so y'all know, I have the equipment, materials, and skills... I CAN build this...  but if I do, I want it to be functional, and downright cool, so I'm looking for suggestions.
I'm considering building a motorcycle based on an Allis B engine.
I'd build it stressed-member... meaning the engine IS the frame... the front half (steering tube, triple-tree/forks etc) would bolt to the front of the engine... while the rear half would bolt to the rear.
Yeah, I'd hafta use an Allis fuel tank... and a pair of tractor headlight buckets... and a steel pan seat.
I considered using an ag-tread rear, and a tri-rib front, but... they're not DOT approved... and I'd certainly get it titled and registered as a motorcycle... and I'd wanna be able to put it on the interstate at 70mph.  I'd obviously nix the governor, and hafta make it spin freely from idle, to some speed HIGHER than a normal goverend tractor... mebbie 4500rpm or so.  Lighter flywheel for CERTAIN...
Beyond that... transmission, clutch, rear suspension, drive... all up-in-the-air.  I'm thinking shaft-driven with a single-sided swingarm made from a substantially-reengineered front axle from a Jeep...   or something like that.
Whadd'ya think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2019 at 10:03pm
Too much down time? Just kidding. It would be interesting. Not much help on design ideas though. Best wishes on your idea.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2019 at 10:29pm
I usta think a JD A engine in a VW Beetle would be the thing to have. You could reach out through the windshield and push the clutch in.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2019 at 10:59pm
I was with ye making a new super duper collider snow machine with settings set for Blair Nebraska...and snow that dude that has thet snow maker under about 30 feet os snows....
  ... but ye lost me at the word 'motor snickel'...Disapprove
  If that engine can hold the tractor up, even after it comes dropping down, it should be tuff enough to be used that way too for holding the front assembly of a motorcycle on the road at 70 mph. Dave B Cool...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 12:18am
I think you been getting into the new years bottle too early Dave....  LOL
All laughing aside, that's how BIG things got started.  I can picture it in my mind, so it would be FUN!
HAS to be water cooled, tranny would be a real problem as you wouldn't have to shift... suspension??  GOTTA have the shocks that hold up the seat of the WD/WD45.
I still think you've been into the new years stuff too deep...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 5:14am
Dave, make it interesting:
[TUBE]WpUcRYq73YY[/TUBE]
Not like this:
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 5:38am
DIYDave's  Second Picture Link To Picture
Edited by chaskaduo - 30 Dec 2019 at 5:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 5:44am
Idea but not the color. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 5:44am
not that crazy....considering my 'silly' idea... still a work in progress..SSQA mount .
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 5:52am
JayB, I've been toying with that Idea for my B for up north. Slowly getting parts together.
D'Kamp, ya gonna paint her metal-flake orange?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 10:21am
 Well,,,I'll wager that when ole Dave puts his mind to thet project,,,,it gonna be very interestin and thourough,,,,ClapClap
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 1:52pm
I agreed with Ted J
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 8:41pm
Okay, well, that green tricycle has a built=in headrest... LOL
Like I said... highway-driveable... suitable for a license plate.
Yeah, I think the B engine is structurally suitable as a stressed-member.
I also think that it'd be okay spinning a bit faster than it's governed speed without too much worry.
Getting several speeds out of it, and driving the rear wheel... will require some engineering prowess, but fortunately, the B engine is narrow, so it won't be difficult to straddle.
I'm thinking that if I can make a transmission bellhousing with integrated swingarm pivot,  tuck some spring-overs underneath, the rest is just figurin' how to get a transmission in there, and drive to the rear wheel.
Magneto, carbeurator, and hand-start...
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 9:50pm
I believe the Boss Hoss motorcycles used a modified power glide tranny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 11:12pm
No question an automatic would be handier than a suicide clutch/manual although not as "cool". Hey! How about some kind of hydro drive and driven setup? Can that be over driven?. Chug along while orbit is buzzing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 11:57pm
I have faith in you, i'm sure you can do it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 4:51am
I have the best transmission, to use:Wink
[TUBE]Ac7G7xOG2Ag[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 7:23am
Oh, Man- I forgot all about the TurboEncabulator... Dang... okay, lemmie see... I think I got one, mebbie two'a those in the pole barn... underneath the shelf with the Sachs air-cooled Wankel rotary...
The 'early' Boss Hoss uses a 90 degree gearbox coming off a conventional clutch housing, and a vacuum booster.  I say 'early', because the one I rode (my neighbor built one) had it... I dunno if they've changed it since then, but the gearbox was really similar to one you'd see on say... a bushhog mower... but the gears were cut for much higher speed operation.  A mower gearbox can take a beating, but their upper speed limit is about 1200rpm.
Hydrostatic... hmmm...
hmmm...
hmmm...
BTW... Bud Haggart was a talented guy.  I could NEVER make it through that video without breaking out laughing, much less choking up on the technobabble... but he could do it with a totally straight face without losing a beat.  I'm thinkin' the cameraman had earplugs on, and his head in a paper bag, to keep from throwing Bud off...
Edited by DaveKamp - 31 Dec 2019 at 7:28am
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 10:28am
There are a couple of "bikes" around here similar to what you want to build.  One is powered by a flathead Ford V8, the other with a smallblock  chevy. Both have no transmission, just a clutch and some type of angle drive.  Engines have plenty of torque so a transmission is not required.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 10:47am
Might have to take the motor to a specialist shop and have it balanced through and through. Other than that. -- its a go for it.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 8:08pm
Flywheel would be my big concern at 4500 rpm.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 9:23pm
And here I am just trying to get a tractor to run.
Back in my younger days I'd fight you for a chance to ride it, now, I'll just take pictures, show people and say, I know this guy. . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 1:54am
Well, after thinking about it, Mike, and Tom... if I were to go hydrostatic, I could certainly limit it to under oh... 2500, and run my hydraulic ratios with final drive to yield sufficient road-speed without having to spin it that fast.
Let's say I use a shafty swingarm, and couple a hydraulic motor to it... a 29" OD tire being somewhere in the vicinity of what... 750 rotations per mile, that'd make 60mph occur at 750 TIRE rpm.  If it's a 4cyl Goldwing rearend, it'll be somewhere 'tween 3.09 and 3.44:1, so that'd be around 2500rpm of the driveshaft.
If I use a hydraulic motor suitable for 4000rpm, and a hydrostatic pump that, at full-swash, yields a .50 ratio (meaning, two motor rotations for 1 pump rotation), then the B's 1800rpm would swing 3600 at the driveshaft, which comes to 1091RPM, which with that 750 rot-mile tire, yields 1.45 miles per minute... that's 87.28mph.
I'm thinkn' that'd be more than fast enough for my intentions.  At 65mph, that engine speed would be 1800/60*87.28 = 1237rpm.  Yeah, that'd be a comfortable engine speed...
Hydrostatic drives are thermodynamically inefficient... in the case of lightly loaded, they're a LITTLE better, because there's less waste heat generated.  Cooling the engine and the hydraulic system will be an interesting exercise... and I'd need an oil reservoir for the hydraulics.  I could use the frame as a reservoir, but that means the frame would get pretty warm.  I could use the engine's oil pan... mebbie fab a new one that's bigger, and use engine oil as my hydraulic fluid, then have an oil-cooler for the hydraulic return... it'd serve double-duty... or mebbie I could nix the aqueous coolant, and do like the Suzuki GSXR-750, just fill the cooling jacket with engine oil...
Hmmm...  that'd be far out, man... nothing but oil coolers...
hmmm...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 9:31am
First thing I thought of when I saw the 'power blide' was the old 50s Chebby trannies.  I thought they are WAY to heavy for what he has intended!!  Then I got to thinking power glide bikes, e.g. Honda.   BIG difference!!  LOLLOLLOL
I hope you're going to have pics all the way through the blueprints to the finished product!!  Gonna be a two seater??  I wanna ride!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 10:29am
Hee hee... 'blueprints'...
Some guys spend a huge amount of time drawing things out, which I understand... some guys spend huge amounts of time building every last piece, before ever making one component...
Unfortunately, Ted, the economy of engineering is biased heavily upon available time use.  Most things I build, get built inside my head extensively... they're 'greyprints'... and it's not unusual for me to pattern parts from cardboard, plywood, and thin sheet, then go straight to the finished part, in a very short number of steps.  I tend to limit my design time to forward-motion aspects of a build, the rest happened in the past... I just take it from the original concept format, to metal.  I expect to change design aspects , but not 'till after I've done some testing on mock-ups, and oftentimes, those mock-ups are metallic, so I just dig in and go.
I wouldn't leave 'ya without pictures, though.
And I just remembered- I got a stuck B engine down in the barn...
This page was generated in 0.555 seconds.
