WD45 Knocking Noise
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Knocking Noise
    Posted: 25 Dec 2019 at 3:50pm
As I was bush hogging today, my WD45 started knocking. Has good oil pressure. Push in on clutch it quiets down. Noise does not change with PTO engaged or disengaged. Transmission bearing? Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 7:13pm
"Push in clutch and it quiets down" ??  Does that mean the noise completely goes away?? or is just less noisy, and is still knocking some ??  If it completely goes away, shift the transmission into any gear and throw the hand clutch lever forward and then let out the foot clutch. If the noise has returned, it is not in the transmission, but is in the center torque tube section and is probably something in the upper PTO drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 8:58pm
Sounds like the hydraulic pump. Pull hydraulic lever down and see if it quits. MACK
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2019 at 10:56am
x-2 on the position of the hyd. lever!---they creep up and max out the cylinders,---makes one hell of a noise!--first time mine did this, I bout bailed off!--gets your attention real fast!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 6:59am
Not the hydraulic pump, lever up lever down makes no difference in sound. Put tractor in gear, hand clutch forward makes same knocking as in neutral. Push in on foot clutch noise quiets to not noticeable. If in PTO drive , how hard to fix?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 7:04am
To be sure it still isn't the hydraulics pumping, your lift arms can be lowered and stay lowered with the hand lever down, right ???
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 7:30am
Yes, hydraulics function as usual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 7:41am
So, it appears to be in the PTO drive area. There are five gears for that. I guess you start by draining the oil at the PTO box and removing the box. You can see 4 of the gears from that point.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 8:18am
If I find a problem with the gears, how big a job to get to them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 9:10am
Two gears are actually inside the PTO box, so start there. The next two are up inside and require hydraulic pump removal. The last one requires the tractor to be split in two at the battery box area.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 10:40am
I hope it doesn't require splitting the tractor. It makes the same noise whether the PTO is engaged or not. PTO still spins with bush hog attached.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 11:01am
Whether the PTO is engaged or not, four of the five gears are always meshed and turning when the foot clutch is released. Only the very bottom sliding gear isn't meshed when PTO is disengaged.
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 11:06am
Well I guess I may get ridiculed for stating the obvious BUT - if it just suddenly started making the noise while bush hogging, have you checked the oil level at that fill point? I had a similar situation back a couple of years or so (and before I did a lot of work to mine last year/this spring), the PTO gearbox seal was leaking fluid and I hadn't noticed. Corrected that, all the noise stopped.
OK flame away lol
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 11:30am
Good idea, sometimes we overlook the obvious!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 9:33pm
Seems like the intermediate gear is the one that loses a tooth. I have broke 3 in 40 yrs. Last one was 2 yrs ago and it made a ticking sound at idle with PTO off. Never really knocked.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 10:34pm
OK, maybe I'm thinking too obvious, but could it be a broken spring in the foot clutch. Or possibly the throwout bearing getting loose on the clutch fork. Or maybe pilot bushing getting bad?
Edited by truckerfarmer - 27 Dec 2019 at 10:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 6:15am
Not likely.        MACK
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 6:28am
One tooth off a gear might only tick, but a couple of teeth off and it will be more of a knock!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 8:17am
Folks,
My 2 pennies, As mentioned I have heard pumps making a knocking noise when they go south. Friend had one go bad and was very noisy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 12:17pm
one of my 45's pump sounds like a cornsheller. as long as clutch is engaged it knocks, arms go up and down just fine, pump still knocks bad. ---I think you can drop the pto box and see IF the drive gears are ok or missing teeth, then go from there.
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2019 at 10:48pm
Allis Wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 7:13pm
I'm currently working on the P.T.O gears on my WD45 and I was missing numerous teeth on the Intermediate gear, a few off the Idler Gear and 1 off the sliding gear and it was more of a knocking and banging when the clutch was released instead of a tick-tick. It was loud enough I was looking for holes in the side of the torque tube after I got it shut down.
Edited by Allis Wd45 - 30 Dec 2019 at 7:15pm
WD45
IH Cub Cadet 149,1650,1250
#2 Cart, IH#2 Tiller
