replacement track wheels for HD16
scooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scooper Quote  Post ReplyReply Direct Link To This Post Topic: replacement track wheels for HD16
    Posted: 23 Dec 2019 at 10:42am
I have HD 16 cable dozer.
Track wheels need replacing.
I have had no luck sourcing replacements.
Any one here know of a possible lead?
Thank you.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 12:48pm
Try  general  gear  1-208-342-8911      John  Parks.         Tony
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 2:30pm
IIRC there were different track chains during the HD 16 series
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 1:02pm
You might try Fresno Tractor Parts. (CA).
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 1:10pm
The other Option, sounds bad where will look worse is to Upgrade to Cat Rollers, the Idlers can be weld built up and turned back, at worse for sprockets is weld in cups or attempt to find Rings.
All I have ever seen on HD16 was 7.85 pitch. On Worn Sprockets Cat 8.0 may work.
Edited by DMiller - 24 Dec 2019 at 1:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 3:09pm
A neighbour has a 16DP.  IIRC the chains are wider - not sure about the pitch
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 8:32pm
Do you have a serial number of the machine? We might be able to locate some. Just rollers?  We don't consider ourselves in the parts business...we do have several HD16s..for parts..probably more than we need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scooper Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 8:57am
First thank every one for the leads
Serial # for the machine is 5150
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 9:00am
16 and 16d are same.  DP and 16b different animal
