Off color IH 1568 V-8
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Topic: Off color IH 1568 V-8
    Posted: 19 Dec 2019 at 2:48pm
I was going by Nyssa tractor salvage and thought I would stop in to see if they had any new orange, nope no luck on that.  This was setting out front, you don't see them too often so I thought I would snap a few pictures.  I did not go back in and ask them what they wanted for it.  Could probably call if you were interested.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 2:51pm
I'd love a 1468.  1066 is on my bucket list.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 3:20pm
By appearance of stacks this is a custom build not factory.
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 4:17pm
My neighbors had a 1568 when I was a little kid.
They got rid of it 20+ years ago when they were worthless, now they are worth a small fortune.
A little CQB never hurt anybody.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 4:54pm
Quite a collectors item by IH fans. Not the best track record when they were used for farming. Neighbor had one that threw a rod out of it, fixed it, then threw another rod. Traded it for a 50 series JD. Looks like a good survivor tractor. Personally, I would rather have a 1468. You don't get the planetary transmission, and open-station was standard. they look better to me as a fender tractor. All 1568's were cab tractors. Any without a cab aren't factory.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 5:41pm
Ford fans love those raggedy arse V-8s Those 550s were the predecessors to all the Ford P/U  V-8s
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 5:57pm
They weren't real popular and when the motor went a lot had DT466's stuck in them because it was cheaper and more grunt
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 7:27pm
It's factory.  The 68 series was a 550 V8.  66 was a 414 or 436 for the 10/1466.  Pretty sought after, but the straight 6 was a much better engine.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:18pm
AaronSEIA
Agree.
The frames are form fitted to the engine. If you replaced the V-8 with a Six cylinder, you had to get the Six cylinder frame rails.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:22pm
in the magazine "farm and ranch" someone put a 3208 cat v-8 in a IH 706, it looks really good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:23pm
About 12 or 13 years ago, a friend of mine was at an auction that had two of them on the farm. The auctioneer offered choice out before he started selling them. My friend was bidding and asked me which one he should take if he won the bid. I told him take them both and I would buy one from him. He didn't bid enough so the rest is history. They sold for around $5000 back then. Hindsight.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:50pm
They were not very efficient on fuel consumption. The same HP 6 cylinders were more economical. I still like them for the sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 11:12pm
Ok before we get anything started here, we know V type engines are just as good as their 6 cylinder counterpart, just look at Scania, MTU, MAN, GE and EMD, they all got it figured out.
Just sayin'
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 5:56am
Guess I'll weigh in since I've been around a few. They used to be cheap. I once watched an engine and rails from one that had been changed out to a 466 sell at auction for $25.00. They also had a sequential fuel system that would run four,six or eight cylinders depending on load. Usually that got eliminated. They aren't putt putt around tractors. Big fields and full loads was what they liked best. I do believe the engine was a derivative of the 549 gas. Personally I'll take one over a 3208 CAT or a V8 Perkins every day.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 7:16am
They run on 4 on light load, or all 8 once more load is applied. At no time do they hit on 6. It is in the pump, the 4 plunger and barrels are cut for this. When rebuilt, many choose to put all 8 same plungers in to eliminate the rough running when on 4. They do sound odd.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 7:59am
I had a customer that owned one.  He said it was the cause for him having to wear a hearing aid!
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 9:22am
They make really nice show or parade tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 9:58am
Just sayin'
I was referring to fuel usage per the Nebraska test numbers and not my opinion. I also talked to farmers of that period that had one and had the same story. I do like the V8's and would like to one.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2019 at 8:34pm
One of my neighbors has one that looks like it came off the showroom floor. He does some local parades with it.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2019 at 10:55pm
There are circumstances where engine designs in THEORY are more suitable for one application than another, and for many reasons, including, but certainly not limited to fitment, weight, visibility, serviceability, torque level, working RPM range, fuel consumption...
Side effects of design always include trade-offs... with V engines having different stroke-to-rod-length ratios, inlines having longer crankshafts and taller blocks, inherent differences in piston speeds, etc.,
And then, there's the fact of wether or not the aforementioned circumstances play out in PRACTICE.  A perfectly good engine design could flunk the Field-Use Value in a very short time due to the slightest overlook in engineering and testing... like when an engine is operating across a hillside, and the downhill rocker cover doesn't drain back to the sump, and the oil pump starts sucking air, and the rod bearings all fail...
So any argument of 'better' really has nothing to do with the V vs. Inline design.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 7:01am
No such thing as a downhill side on a straight engine
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 5:07pm
There is an interesting white paper by E.W. Kettering, about the development of EMD's 567 engine. When talking about the piston rod bushings, (I love this line), "Someone who didn't know that bronze bushings wouldn't work, put them in, with great success".
Edited by bigal121892 - 23 Dec 2019 at 5:08pm
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 12:25pm
Scania engines are total crap. 10 years ago we had a couple in test cells and the leaked out of every mating surface and vibrated everything loose. We called them Skankia.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 9:20pm
we had a 1568 at the career center in high school, that engine was worn out because it was taken apart year after year by a different group
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
