Belly Mower
RAR45110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RAR45110 Quote  Post ReplyReply Direct Link To This Post Topic: Belly Mower
    Posted: 18 Dec 2019 at 10:35am
I have a D10 and want to attach a finish belly mower.  What is the best mower to fit this tractor?  I have seen the Woods L59 recommended for the B, but do not know if this will work with the D10.
When asked how it feels to be the smartest man alive, Albert Einstein answered, "I do not know, you'll have to ask Nikola Tesla."
1938 B, 1938 B, 1942 B, 1959 D10, 1959 D12
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2019 at 1:04pm
It's all about the brackets. They should have the D-10 kit. If not you can get the closest kit and modify accordingly, OR just get the mower and make all of the brackets yourself!
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2019 at 4:06pm
The D-10/D-12 essentially replaced the CA as far as horsepower is concerned.  I have a Woods L-306 on my CA and get along fine.  But, I don't think there is any provision on a D-10 to allow you to stop forward movement and still run the PTO to power the mower (i.e. if you get into tall grass, etc.).  I might be wrong about the live PTO but I don't think so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2019 at 4:21pm
The B brackets would be the ones you want to start with for a D10. The CA brackets would work on a D12.  If you don't have a model with a belt pulley, you'll need to find the large PTO pulley that WOODS made.  The rear mount that WOODS made for the D10/12 mowers was adjustable to fit both the narrow D10 and the wide D12.  The lift bracket that bolted to the torque tube left something to be desired as for durability. It was bolted on with 2 of the 5/15" bolts for the side sheet in front of the break pedals.  I believe that something more substantial would not be to difficult to make.  Either a L59 or L306 would work fine on a D10.
Edited by PaulB - 18 Dec 2019 at 7:18pm
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2019 at 4:53pm
The series III D-10 has live PTO.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 1:01pm
Dusty, thank you for the correction.
Brian
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 2:23pm
I'm not familiar with the D series but I have a L59 on my C and wish I had the wider L306. I have a L59 on a B and it works great. Just something to think about as you don't have a mower yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RAR45110 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 9:34am
Thanks for all the input.  I will be looking for the L306 mower.
Thanks again,
Bob
JD-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 10:11am
A lot of the parts and mounting hardware are still available from a Woods dealer. Used is better if can be found because of prices for new.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 11:21am
I put a three point on the D12 I had and pulled a Woods 6' mower behind it.  I had a L59 on a Farmall A and didn't care for it.
